Box Nation Activation on Sky box HELP!
  • borderfox
    • Apr 2010
    • 39
    Hi there. I have just subscribed to box nation. However, I can't get it to update - and I suspect the problem is due to my sky box.
    I have a hd box. However, only have one input feed. I think I can change settings somewhere on the skybox (by sky box, I mean an original receiver from sky!) - so that both the broadcast and the update are received down the one line. Can anyone let me know how I can reconfigure this on the sky box??
  • ramjet
    • 2995
    sems simple to me , ring up sky and get them to sort it , job done
    • borderfox
      • Apr 2010
      • 39
      It would seem to be the case but I'm not a customer of theirs. I just have box nation on there as of today ...or at least that's what I'm trying to sort out.
      There are settings that can be changed so that both updates and the broadcast data both come in on the one feed. It's navigating those settings that I'm unsure of - but I would imagine this must be ground well covered by someone else out there..??
      If so, your post would be welcome.
      • Manic01
        • 5117
        You have Box Nation sub, no other sub?
        • borderfox
          • Apr 2010
          • 39
          Exactly (or at least I will have once I can get it activated!)
          • zee24
            • 3342
            do you have the white sky card in your box or do you have the old blue card?
            • borderfox
              • Apr 2010
              • 39
              White - there's no issue there. I would imagine the issue is that the box - by default - would have been configured for dual feed (it being a sly plus box). I need to change that to single feed - so that ALL data is received on that one feed.
              For example...when I tried it this morning, the epg data was coming when I switched the feed to the other input. When I switched it back to the other input port/connector, then it could receive picture (when testing on free to air channels).
              I would imagine it would be the same deal when box nation send the 'signal' to activate - it will activate on the other feed/via the other port ....but as I have only one feed......
              ...you see the problem?
              • Manic01
                • 5117
                I thought you needed an active sub to subscribe?
                Heres how to switch to single feed on sky hd box
                Go to engineers page:
                SERVICES 0 0 1 SELECT
                Scroll down to Single Feed Mode, and toggle left/right to ON
                GREEN button to save, and single feed is now selected
                Thanks to Highlander @ DW
                • rigsby71
                  • Mar 2009
                  • 676
                  It shouldn't really matter whether your box has one or two lnb inputs in place.
                  I also have a sky HD box & i only ever use it to update ..
                  1 my Sky only card
                  2 my box nation only card
                  As you see i have TWO white cards, one has all Sky on it, the 2nd card ONLY has Box Nation & the Free stuff on it.
                  But when i update the card, i only EVER use one feed into the SKY HD box, so it does work & as Manic says, just set the box to one input only if you wish.
                  Mine is still set to two inputs by the way, but as long as one of them gets the signal, it shouldn't matter.
                  As long as you can get a Signal (Try BBC 1 for example)
                  then go to the channel Box Nation & simply leave you card in the box & wait for the update.
                  It doesn't matter if you have Sky or not, you can have Box Nation on it's own & they send the signal to update.
                  Just call Box Nation if you still have trouble & they can sort it.
                  • Manic01
                    • 5117
                    I have a white fta card, can this be activated?
                    • rigsby71
                      • Mar 2009
                      • 676
                      Yes, in the official box.
                      You can subscribe to...
                      Asian Channels
                      Racing UK
                      Premier Sports
                      Box Nation
                      Setanta (In Eire)
                      Probably a couple more aswell
                      You don't need to have a Sky package of any sort to subscribe to any or all of the above.
                      • Manic01
                        • 5117
                        Thanks mate, have already contacted them and advised of the same.
                        Trouble is they want postcode of card and I got card with 2nd hand stb.
                        • rigsby71
                          • Mar 2009
                          • 676
                          Just give them your postcode, it won't be a problem unless you don't have one ofcourse.
                          • Manic01
                            • 5117
                            Thank you for contacting BoxNation.
                            You will need a viewing card which is registered to your address. You will probably need to get a new card from Sky.
