snr reading lowon certain channels
  • alotmentman
    im banging me head on certain channels getting reading of 63% on snr no signal on channel yet others 90% got channels could some tell me the problem tried at mates house all channels 93% and working is it a fault on the lnb on dish ive tried new cable still same please help
  • Manic01
    • 5117
    What receiver?
    Have you checked lnb is ok?
    Is dish misaligned?
    • alotmentman
      dm550s mate it works fine at mates house ;lost some free channels and others eden etc all those that lost lnr reading 63 %
      • smoggie
        • 863
        if its fine at your m8's, then you need to check your set up. cabling, dish alignment, lnb etc
        • gracieboo
          • Dec 2010
          • 368
          Hi there see if you have got the skew right on the lnb. maybe if its a little off you are picking up the stronger transponders. Try a little movement clockwise and then anti clockwise and get someone to watch the signal.
          • alotmentman
            lnb
            sorry ta sound dumb wots the skew mate ive got a old sky box i put that on that picks all the free chans up ok .but the dreambox doesunt.....does the dreambox run on different frequencys mate thanks for reply will try adjusting dish today .....its threw me out because old sly box pickin channels up but dream box lost some chans there showing up but no signal ......yet they box works at mates house all chans not working snr low ie in 60%
            • ramjet
              • 2995
              its the same transponders on the satellite and so uses the same frequencies and symbol rates etc
              so no the 2 boxes dont use different frequencies
              skew is the angle at which an lnb is turned in its holder when facing the dish face, and on a sky dish its turned slightly clockwise so that the cable leaves the botton at about 7 o clock and not straight down at 6 o clock
              so whatever the sky box can do, so can the dreambox
