Best satellite for football?
  • footyaddict
    • 86
    I currently have a 80cm dish pointing at 4.8e, what's the best satellite to use for a wide choice of football? I'm looking for as much as possible... Serie A, Bundesliga, Ligue 1, MLS and any other major leagues.
  • johnny yen
    • Feb 2010
    • 60
    13 east nova, al jazeera ,sky italy
    • rigsby71
      • Mar 2009
      • 676
      Yes, probably Hotbird is number 1 for variety of leagues.
      • pedro2000uk
        • Mar 2012
        • 44
        The best bet nowadays for getting the footy is just to go motorised to help deal with what the EPl are doing with the 3pms & whatever else they've got up their sleeve etc.. so no matter where your team is on you can get to it- some if it free.
        otherwise ... atm... another vote for 13e if it has to be fixed.
        • footyaddict
          • 86
          How much would it cost to get a motor installed on my current dish?
            Not Much between ?35-?55 and easy enough to do it yourself
            • pedro2000uk
              • Mar 2012
              • 44
              It's not usually just the cost of the motor at c. ?45, it depends if it needs new brackets too - motorised usually need better brackets anyway to get the most out of them accuracy wise, deal with strong winds & clear walls as the dish moves etc... plus it should see the whole visible arc & loads of satellites rather than just one satellite so might need moving or even going long pole over gutter/ roof etc.. which needs even better brackets & pole to do well or you just end up with a flag pole waving in the wind on aerial brackets- there's a lot like that.
              But if it's just a used 80 & most 80s are under 80 so you won't get the weak stuff too well if at all- you could get away with a cheapo motor & less than perfect brackets just to get at several sats just for footy & forget trying to get the full arc for now.. then you could move between a few sats like 1w 4.8e 13e 16e 19.2e etc.. possibly from where it is already.
              If you did get a cheapo motor though & later wanted to get a better / bigger dish you might need another motor.
              Motor installs do vary drastically from real crap to real pro installs even for the same size dish, like anything else.
