Need some help on setting up freeview sat
  • oneellis
    • 8
    Hi Can some one help me with setting up freeview sat.
    i`m looking at setting up 3 rooms with freeview sat
    i`m on virgin cable at the moment, but have a sky dish on my house and want to set up my 3 rooms using the dish
    Not 100% sure what i need
    need help from the dish to the wall socket
    the other question is do i use the dish or can i use my cable
  • cactikid
    • 12017
    ok each room will need a sat cable feed to each box if its a single tuner or 2 cables if its a twin tuner box.
    your sat dish may need a bigger selection of lnb socket as your dish may only have a double=2 cable,or 4 lnb=4 cables or use with 2 sky+ boxes that have 2 feeds.
    each room needs a cable or 2 and a box.
    or if you ouput from one room the picture will be the same in the others,it depends on what you need or more info.
    • ramjet
      • 2995
      3 rooms with a single feed to each room is 3 coax feeds from a quad lnb on the sly dish
      if you need 2 feeds per room you need an octo lnb on the sly dish
      no you cannot use vm cable feed for this
