New Setup - Help Needed!
  • neldog
    • Apr 2012
    • 28
    Hi Guys,
    I have moved to Germany and require some help!
    I am living in a city called Bielefeld if that helps anyone.
    My current idea for setup includes:
    1 x 80cm Satellite
    1 x Technomate 5402
    3 x LNB
    1 x LNB Bracket
    1 x LNB Leads
    Does anybody see any problem with this setup?
    I want to receive Astra 28.2, Astra 19.2 and Hotbird 13.
    Is the Technomate 5402 good? Is it easily configurable? Can it record and stream 3D?
    Is there different boxes in the same price range for better value for money?
    How do I configure my receiver, when I buy one, to know that there are 3 LNB's on my satellite, or does it pick it up automatically?
    Any help is appreciated!
  • Nutsandbolts
    • Oct 2011
    • 1168
    Hi. Why not buy a motor its cheaper than 3 LNB's and switches etc. If you still want 3 LNB's then you will need a 4 way Diseqc switch. Basically you connect your three 3 satellites LNB cables to the switch ports (labelled as 1 2 3 and 4 or A B C D). You then connect another cable straight to your receiver from the 5th port on the switch. You then have to set up your receiver to connect to the switch. I dont have your receiver but i have a TM5400 model and i tried this setup a couple of years ago and worked fine with a TM 4 way switch. I will give you further details later as i dont remember the menu options you need to take. Regards.
    • neldog
      • Apr 2012
      • 28
      Hi Nutsandbolts, thanks for the fast reply!
      I would prefer a motorised, like I have in the UK, but the problem is here in Germany I cannot find any motorised dishes anywhere, unless you know somewhere?
      You can buy dishes and motors seperate, but I don't know which motors fit which satellites!
      Is 80cm big enough to get what I need?
      Cheers
      • ramjet
        • 2995
        Cheers
        80cm should be ok for 13e and 19e but you need to check the footprints of the 28e satellites to check dish sizes required for 28e in that location as some transponders are tightly beamed onto the uk
        I do not think you can stream from a tm5402 as that function tends to be a feature of some linux boxes
        the diseqc 4 way switch system will do the task unless you want to use a motor. almost any diseqc motor will do the job but ideally you want a darkmotor or the tm2600 motor which are both diseqc and can handle dishes of up to 1.1 metre
        most boxes are now diseqc/usals only and so a diseqc motor is standard unless you go for a massive dish using a polar mount which you arent
        unless you need the extra features of the tm5402 then a blade bm7000s may suffice and is easily configured
        a linux box is always better but more complicated to setup but should allow streaming
        • neldog
          • Apr 2012
          • 28
          Hi ramjet,
          What do you mean when you say cannot stream from a TM 5402?
          My location is bielefeld, germany if I can check somewhere the footprints (sorry newb here!)
          I would like to go the satellite route but need more information on how I actually set it up on the box.
          I have a person that can allign and install the satellites but no idea how to configure a TM to store Sat positions!
          Cheers
          neldog
          • ramjet
            • 2995
            Hi ramjet,
            Cheers
            neldog
            you asked about streaming in your opening post , and I said I do not think it can be done on this box (I do not own the box but do have a blade which is very similar)
            so you asked if it can stream and I said I do not think it can stream - simple as that
            there is a techomate section here on DK where you can get more info on technomates , dont assume everyone on here has one as there are hundreds of boxes available, but the techno has its own dedicated section which is where you should ba asking the specific questions about the box , like configuring the satellites and switch settings etc
            general sat chat is for general questions and answers, not actual specifics covered in dedicated sections like dreambox or technomate etc
            use lyngsat or kingofsat to check sats and footprints etc
            • neldog
              • Apr 2012
              • 28
              ah ok sorry about that confusion!
              by streaming I meant playing, but it should have no problems playing HD channels right?
              what are footprints? where can I check these?
              • ramjet
                • 2995
                your words are very confusing here
                streaming and playing refer to sending files or content to or from the box
                streaming is where its sent to another pc or another location away from the box , usually over the lan
                playing would usually refer to playing an mp3 file or a divx or mkv file from usb stick or a hdd etc
                I think what you are talking about is connecting a hdmi lead to a tv and viewing the content on the tv - ie:- VIEWING , not streaming and not playing either
                hope I am right
                in which case yes it will show HD channels as well as SD channels on a hd equipped tv , usually using a hdmi lead
                check my last answer for websites to check footprints
                • neldog
                  • Apr 2012
                  • 28
                  you are right! I want to view not stream!
                  will post back with footprints etc
                  • neldog
                    • Apr 2012
                    • 28
                    Hi, sorry but been on lyngsat and kingofsat but both are bad on the eyes and I can't find anything to get footprints etc, I have however been on another website, satpointer.com which returns the following for 28.2 from my current location:
                    Satellite Dish Setup
                    Skew of LNB: -14.7?
                    Dish | Elevation: 27.7?
                    Azimuth | True: 155.61?
                    Azimuth | Magnetic: 154.15?
                    Location on map
                    Latitude: 52.0213?
                    Longitude: 8.5303?
                    Satellite Info
                    Name: 28.2E Astra 2A + 2B + 2D
                    Distance: 38817.89 Km
                    • neldog
                      • Apr 2012
                      • 28
                      Satellite Name / Direction: Satellite Beam Est' Dish Size(cm)
                      28.2E Astra 2A + 2B + 2D N/A
                      AST02ANO Out of zone / Unknown
                      AST02ASO Out of zone / Unknown
                      AST02BNO Out of zone / Unknown
                      AST02BSO Out of zone / Unknown
                      AST02CKU Out of zone / Unknown
                      AST02DKB Out of zone / Unknown
                      EUB001KF Out of zone / Unknown
                      EUB001S1 Out of zone / Unknown
                      EUB001S2 Out of zone / Unknown
                      AST02ANO 52 50
                      AST02ASO 52 50
                      AST02BNO 52 50
                      AST02BSO 52 50
                      AST02CKU 53 50
                      AST02DKB 52 50
                      EUB001KF 54 45
                      EUB001S1 49 60
                      EUB001S2 38 150
                      EUB001S1 38 150
                      • ramjet
                        • 2995
                        here is an example coverage map for astra 2d , just use google to search for others if unsure
                        Astra 2D reception Maps
                        also check using dishpointer website too
                        • neldog
                          • Apr 2012
                          • 28
                          OK, have figured out that 80cm is more than feasible for my location to get 28.2..
                          Now it's down to which satellite!
                          What is the difference in these 2, except price;
                          SAT-Spiegel Smart 80cm Stahl Grau | voelkner - direkt g?nstiger
                          SAT-Spiegel 80cm Alu Anthrazit, SCHWAIGER | voelkner - direkt g?nstiger
                          • neldog
                            • Apr 2012
                            • 28
                            If anyone could also let me know if this is an LNB multiswitch?
                            • dick b
                              • Jun 2009
                              • 2462
                              dont know either of those 2 brands but I"d go for the ally one,
                              I use a gibertini 85cm in the uk with 4 lnbs mounted on a gibertini multi lnb bracket these feed a 4 way Diseqc switch.
                              you do not want a multiswitch.you need a diseqc switch.
                              If you are setting this up youself a motorised system will be easier.
