Test CCAM with only one sat line
  • Bann32
    • Oct 2011
    • 518
    I want to test that I have set my box up to correctly share the details with another box (or in this case my pc), but I only have one line from my satelite availible.
    Will my Dreambox share the details if it doesn't have a satellite line going into it?
    Im not too concerned if it takes a while its merely for testing sake at this stage.
  • ramjet
    • 2995
    if the line has reshare rights the dm will share it back out , if not , it wont
    no satellite cable needs to be connected for this to happen , its merely acting as a server , or in this case a reserver as its resharing
    so it wont reshare if its prevented at source from doing so
    you can turn the line off on one box and test it on other boxes , as long as its only used once , so you can test 10 boxes with one line , just one at once only
    • Bann32
      • Oct 2011
      • 518
      I was using the ccam as my client and passing the details to oscam, but oddly it stopped working for no reason, I just wanted to see if I had all the details right.
