satellite dish installer west midlands
  • pob639
    • Feb 2008
    • 224
    After a sat installer local to walsall area n rough price to align n set dish on arc .
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5611
    Im not sure where he is located but no this forum we have a member who is a installer, his name is terriers or something like that! Try private messaging him to see if he is nearby
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • terriers
      • 580
      hi m8....your a bit out of the way for me but i will try and talk you through it so you can do it yourself....
      firstly you need to make sure your mounting pole is level in all directions...then mount your dish on the pole,without the motor for the time being,and lign it up to thor 0.8 west using your signal strength meter on your receiver,if you set your elevation to 30deg to begin with you will find thor quite easily..
      when thor is found tighten nuts up to keep elevation on dish,and mark with a marker pen the centre spot of the dish bracket on your mounting pole.......then you can take dish back down but dont mess with the elevation............
      now we are ready to mount the diseq motor......
      put the motor in place and centre the motor on the mark you have already from mounting dish previously,,,,and the motor is now perfectly set on thor.......................
      now you can mount the dish on motor pole,,,,50mm from bottom of pole and no need to adjust elevation on dish cos its already set......now all we need to do is adjust the elevation for the diseq motor......set it at 30deg same as dish elevation and now your all done...you can search for other sats using the motor control on your receiver,,and if you follow this you will get it right first time without any messing about needed.....have a go yourself you can do it ......
      • pob639
        • Feb 2008
        • 224
        Thanks for the reply but im not after putting my own dish up its for a freind and i haven't got time to do it
        i've got a 1.1m fluke dish 0.1db lmb and a jeagger 99g motor with my dreambox 7020si that i set up a long time ago
