Vu+ duo alternative
  • Bumsrus
    • Apr 2012
    • 65
    Vu+ duo alternative
    Hi guys . Now on the look out for a new receiver as my clone vu+ has gone to receiver heaven. Ideally want a cheaper alternative to the vu+ duo for my Motorised twin lnb setup . Will be using it for sat football and sly on a pay sever. Also wanted the abiltiy to record on an internal hdd whilst watchig another channel. Whats the best alternative? Many thanks
    Ow also needs to be hd with a half decent epg.
  • mdt
    • 3034
    are you certain that your vu clone cant be recovered? theres nothing really in the ?190 price range with the features and support of the duo although you might be able to get a second hand duo/xtrend/q-box ect for similar money. regards mdt
    • Bumsrus
      • Apr 2012
      • 65
      Gonna try putty and try flashing of an sd card tomorrow but I don't hold much hope. left with a nice shiny box with a red dot
      • dell_xps
        • 2558
        Never give up m8 :-), few options still to try !!
        • cactikid
          • 12017
          can you force flash these boxes with the firmware loader and null modem cable with a pc with xp and serial port if needed.?like the kryptview box powered off press download and power on.
          i presume all ribbons are intact and secure inside?
          • Bumsrus
            • Apr 2012
            • 65
            yes i believe the ribbons are in working order but im no expert
            • potrobber
              • Mar 2010
              • 493
              i still cant see this as junked did you try the info and fixes on ferrari site for these boxs in the pm i sent you yesterday
              was this your first linux box?
              • Bumsrus
                • Apr 2012
                • 65
                yep, tried flashing nfi file using serial cable but that got stuck at 20% asking me to restart machine. And not sure how to set up with putty
                • potrobber
                  • Mar 2010
                  • 493
                  is this a com to com connection as usb converters dont work on clone duo,s
                  im also near sure you need the ic chip in place to do this digicon should know
                    Potrobber is correct no matter if your updating the Kernel or flashing an NFI made image you still need the IC connector in place or else it just will not work, Again also correct on the USB 2 Serial adaptors none work only a WinXP machine with serial port will work.
                    • Bumsrus
                      • Apr 2012
                      • 65
                      Ok thanks for that guys .. Narrowd it down to either a vu duo ( not a clone this time) or a refurbed Clark tech et9000
                      Xtrend Clarke-Tech CT9100 ET9000 ₤339 FREE UK NEXT DAY DELIVERY BEST PRICE
                      Any preferences?
                      • potrobber
                        • Mar 2010
                        • 493
                        any word on the advice above did you have it connected with com connection on computer and ic connection at box?
                          Xtrend Clarke-Tech CT9100 ET9000 ***8356;339 FREE UK NEXT DAY DELIVERY BEST PRICE
                          Any preferences?
                          Dont get the Clarke-Tech/Xtrend model they all have a problem with SR30000 TP frequency on Tuner B and its a hardware fault only the 9200 silverline edition fixed this issue.
                          I would get a Duo official @?295 from most e-tailor's now
                          • dell_xps
                            • 2558
                            Vu original all the way :-)
                            • mdt
                              • 3034
                              Any preferences?
                              do you not have a ic update cable?? do you not know a friend/family member with a pc with a rs-232 com port??... keep trying as when i first flashed my solo it took me 10 attempts in about 6 hours to recover it from the dreaded red light but it worked in the end. dont give up so easily, regards mdt
