Looking For HD Receiver that can update softcam via usb
  • baseball16
    • 21
    Hi,
    I already have a Technomate 5600 which I find easy to use. I need to buy an additional receiver. I want FTA use, preferably HD with being able to update the softcam via USB.
    I do not plan to connect the receiver to the internet but I would like a box that could if I require it in the future.
    I have looked at the Eaglebox HD Mini, the Openbox S11 and the Technomate 5402 HD. Are these boxes ok?
    Should I go for a Eaglebox or Openbox (because of price), do they need to be patched? Can I use the same key file from the Technomate thread, that thread seems to updated regularly
    Are there any other brands/receivers that are softcam compatible?
    Thank you.
  • ramjet
    • 2995
    Originally posted by baseball16
    Hi,
    Thank you.
    many boxes fulfil these requirements , but usually each one has its own brand of softcam
    so eagle boxes have their own , as do spider boxes like the 7000 or 9000 or 9900 , or the tm5402 that uses the technomate files , also blade bm7000s , and dreamboxes and vu boxes too
    I would generally say each softcam is bespoke, so you dont usually use one from another brand
    they all need patching before using softcams
    • kunhi
      • May 2012
      any hd reciver same way?
      • Manic01
        • 5117
        Openbox...
        • baseball16
          • 21
          Can I ask which brand or make of receiver opens the most channels?
          I really thought that all receivers with softcam capability could open all the appropriate channels.
          For example, I have recently got an Openbox S11 which opens less channels than my old Technomate.
          Is Technomate the best way to go? The max I can spend is ?150 - I hoped to spend less (hence buying the Openbox) but it didn't work out as I had planned.
          • ramjet
            • 2995
            without internet access they all open the same channels, including using ucas in the patches and a suitable softcam
            its the "added extras" that are the bonus, or the ones you pay for privately
            • baseball16
              • 21
              Hi, I was advised that on the S11 I could not get E*PN A*erica on 19.2e - I can get this channel on the Technomate.
              I was advised that the Openbox could only have softcam for Ird... and Cy..wrks
              I am sorry if I am wrong but I just want to clarify the situation on softcams.
              • ramjet
                • 2995
                obviously the ability of the patchmakers to deliver the ucas is up to them, but if the developers of those patches tried hard enough then my answer would be correct. they all have the ability to open the ucas channels using a suitable softcam providing the patch makers have done their jobs
                the softcams usually tell you what packages are opened by the softcam on the particular box they are associated with, be it technomate, spider , eagle , dreambox or whatever
                • baseball16
                  • 21
                  I made an assumption and made a bad purchase (for my needs). The amount of research required to buy the right satellite receiver is scary.
                  Thanks for your help ramjet.
                  • jmurf
                    • Jan 2013
                    Hi,
                    I'm in a similar position as the original poster, and would appreciate any advice.
                    As stated above, the opnebox only works with Ird... and Cy..wrks. Do other receivers such as technomate also work with other systems like via****s, nag*******n, b**s and s**a m********d?
                    Thanks in advance
                    • ramjet
                      • 2995
                      Originally posted by jmurf
                      Hi,
                      Thanks in advance
                      not really, they all do pretty much the same thing
                      channels opened by biss and the channels opened by the softcams
                      which isnt a great deal now compared to the old days, as the days of the hacks have disappeared and as you know its either subbed c*rds or cs
                      • MajicM
                        • May 2012
                        • 73
                        No, you're correct. I got stung with that as well, but at least it's only a ?50 box. I've got a DR HD F16 and that opens everything I need.
