Old style 80cm dish bracket & pole advise
  • mdt
    • 3034
    #16
    Originally posted by yerman
    i was going to try and use a multi LNB setup with it, but now thinking it would be too much hassle
    Im now looking at a Triax 80cm Dish
    Genuine Triax TD78 High Quality Satellite Dish 78cm (80cm) Folding Arm Bracket | eBay
    And a Multi LNB Holder
    TRIAX TD MULTIBLOCK MULTI LNB HOLDER | eBay
    I aim to pickup
    13.0E - 19.2E - 28.2E
    are these hard to setup?
    Also i want your recommendations on LNB's
    thanks in advance
    the best lnb,s for normal money today are the inverto black ultra series although the smart titaniums are excellent also, regards mdt
    • yerman
      • 66
      #17
      Ok all ordered,
      As i look at the dish when fitted, am I right in thinking it will be, starting from left:
      i will not be using first LNB holder
      1st LNB - 28.2E
      2nd LNB - 19.2E
      3rd LNB - 13.0E
      As signal is reflected off the dish
      Also what noise level LNB's do I need? ( 0.1db, 0.3db etc )
      Is there any problems with focal lenth?
      Based in Mid East of Ireland
      Great site this is, everyone willing to help each other out
      • mdt
        • 3034
        #18
        Ok all ordered,
        1st LNB - 28.2E
        2nd LNB - 19.2E
        3rd LNB - 13.0E
        take no notice of the noise levels as they are taken from just 1 point in the spectrum but i think inverto and smart are both 0.1db anyway... as regards focal length just ajust the position backwards/forwards and clockwise/anticlockwise(skew)and tighten with the highest ss/sq reading. i dont know for sure as i am in north-west uk but you could be right on the limit of reception with a td78 for a 3 lnb 15 degree spread in your location but im sure maybe @potrobber could give you a accurate reception report as he,s from your neck of the woods, regards mdt
        • dick b
          • Jun 2009
          • 2462
          #19
          deleted post as just seen MDT has put you straight.
          • yerman
            • 66
            #20
            all setup and going well, cheers lads
