Hey guys just installed a motorised dish wiv the protek 9760 . Got plenty of signal but no quality any ideas thanks
No quality on dish
you havent give us much to go on but if you are recieving no quality then try a few different transponders to see if you get any quality readings.. if not did you set your dish up on thor5/6@ 0.8w using usals? have a read of the how to install a motorised dish sticky at the top of the threads and follow it carefully then see how you go, regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
Sorry there wasn't much info I'm new to the sat side off things I did set the dis to Thor then I tried moving the dish from left to right very slightly . I also tried different transponders and no joy there either . Then it started rain so I gave up and thought a bit off advise was needed thanks scottProtek 9760 triax 80 tm 5402hdComment
