Hi im a virgin when it comes to all this i am looking to get a 1metre motorized dish setup mainly for the footy probs going with the AJ card as prem is not a priority i can easily watch those games online the leagues and cup comps the aj channels show im happy with ive heard that the further north you go the worse the signal but i have asked one or two people and they say that sometimes the signals weak (daytime,bad weather etc) but it gets better evening/night time im in liverpool im just wondering would this be decent set up the technomate tm5402hd,orbital 1m dish,darkmotor motor,black ultra lnb,webro wf100 coax,sac gold sef seal connectors,and brackets thats ?415 fit and install is there anything that you could add to that to make it a better deal? or does that represent good vfm
Is this value for money
Tags: None
welcome to DK... for what your after thats a excellent piece of kit which will get you everything between 45e and 45w apart from the weaker birds(BADR5/6)/(NILESAT)/(AMOS) in your location but these need huge dishes in the uk anyway. im in bolton and use a TRIAX TD110 and get 90% of the channels in all weathers. the tuner in the tm5402hd is very sensative and will do what you want in all weathers, the darkmotor is a very good well thought of motor and the inverto black ultra is the lnbf of choice today... personally id go with a TD110 and a STAB 100 motor but thats just me. imho the kit you have chosen will be fine if correctly installed with a good L.O.S., regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
Thanks for the replies folks much appreciated also with the tm5402 i would need to get a cam wouldnt i? I have seen a Irdeto CI+ Duel mode for ?37 worth buying? And i have also seen an AJ card for ?125 with all 10 channels + ESPN added thats gota be worth it hasnt it? thanks again for adviceComment
dont get espn added as even though its broadcast on AB7 and the tm5402 has a great tuner in your location i cant see you geting a stable signal in all weather to decode the signal..
@digicon has more of a idea than me concerning signal levels on the tm5402hd as he,s run some tests on a 1m orbital/gibby so wait until he,s been on to see what he says. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Ok thanks mdt someone mentioned purplesat thats where i copied that sat rig from have you heard of them are they to be trusted? Or do you reccomend any decent installers in the north west?Comment
i wouldnt touch them with a barge pole, give digicon a ring ill pm you his mobile number now regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Vu Duo, ET9000, DM800 (x2), Sat BG,Tring, JSc(i), JSC(v) cards,
AZBox Premium - (archive),Eagle box - (archive), Technomate 6900 Combo Super+ (archive) 24/12/2009,Technomate 6900 - (archive),
Diablo Cam 2.3 & Cas 3 Programmer,Gamma Card (x2),
Quali - TV 4:2:2 (archive),Topfield 5000CIP (archive),
Dragon cam & loader card,
Infinity USB Unlimited,
Motorised 1M Dish, Motorised 43cm, QUad LNB on 28.2e
Find me near J15 M6Comment
ive seen quite a few good reports about purplesat but he is expensive so why pay more for the same job? also have you seen some of the monstrosities on the website although they seem to be where there are line of site issue,s... as we know he,s a little full of himself. id say 75% of sat installs can be carried out by anyone(sat enthusiast) with a grasp of diy and a bit of patience and a proffesional should only be called in imho for... 1.. piece of mind, 2. line of site issues/extreme heights, 3. cant be arsed yourself. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
