totally new to sat
  • jckw
    • 760
    totally new to sat
    hi lads ive just been askled by my father if i can set a system up for him and wouldn't no were to start. im ok with cable boxes but a total noob regarding sat any advice on wot system and equipment i would need to start from fresh i think im going for openmedia box and a motorised dish
    we are all learning each day
  • krazylegz
    • 2834
    this might give you a little help
    Install and point a satellite dish / Tools and needed materials / Tools and needed materials / Puntodepartida.com guides
    or
    [ame=http://www.youtube.com/watch?v=-k_yhxmGlEA]YouTube - motorised satellite tv installation guide[/ame]
    i would recommend T&K brackets over any L pole anyday
    PS3= krazylegz120282
    • jckw
      • 760
      Originally posted by krazylegz
      thanks m8 ill have along hard look before i take the plunge looks a bit daunting is it or once you get box setup the dish looks fineand i can load images on to openmedia boxs wots this all about cams bit confusing
      • krazylegz
        • 2834
        the hardest part is setting up the dish m8....box is easy.
        cams decrypt the channels....out of curiosity what are you planning on getting from satellite?
        • jckw
          • 760
          its for my dad he is housebound and his satalite is on 24/7 loves all football and boxing cricket he is a tv addict also he's struggiling with 46 notes a month
          • krazylegz
            • 2834
            if its genuine sky hes after then unfortunately its not hacked so only a valid subscription or cardshare will work....at the minute the only really good package thats hacked is digitv on 1w but thats going to nagra3 soon so its decision time...do you join a cardshare which the hardest part is finding a good stable one as a lot freeze more times than a eskimo pi$$ing in the artic....other than that you would need a receiver with a CI (cam) slot and invest in a cam and programmer but still sky wont open with a cam.
            • jckw
              • 760
              sorry m8 i thought you could use excisting signal so wot cost r u looking at to get him up and running
              • krazylegz
                • 2834
                depends on what you want.
                your current sky minidish will only be of any use for uk sky on 28.2e satellite/
                if you want a motorised setup...probs bout ?200ish for a setup, could be extra if you want to join a cardshare as you need a linux based receiver for this.....if you want a cam then probs bout ?100 ish for the cam and programmer....then a lot of cardshares you've either got to pay a small monthly subscription or share back a card
                • jckw
                  • 760
                  do u need all this for a card share
                  • krazylegz
                    • 2834
                    for cardshare you'll need a linux based receiver and to join a cardshre...but as stated the hardest part is finding a good one that wont keep freezing.
                    since dont directly all card sharing talk on here type it in google and see what the results are m8
                    • jckw
                      • 760
                      thanks for all the info m8 just shows how much of a noob i am with sat so if i get an linux box will this work on 28.2 or do i still need a card share
                      • krazylegz
                        • 2834
                        you will either need to cardshare or use your official card in, but tbh the sky box is better than any after market box for just using your official card
                        • jckw
                          • 760
                          so if i lower subscription to min package will this pic up sports and the rest
                          • krazylegz
                            • 2834
                            no you will only get what you pay for from your card....unless you join a cardshare then u can cancel your subsciption altogether....but as stated u need to find a good cardshare that wont keep freezing
                            • jckw
                              • 760
                              thanks alot m8 for all ur help i think i understand now he's ~~~~ed im off to the pub to drown my sorrows thanks again m8
