Hotbird keys
Tags: None
alotmentman -
Hi. Not familiar with Openbox but if possible any chance you can post a copy of your constant.cw page with details required so next time keys are available i will try and get the info for your box. Usually i only get the keys without any CAID,SID etc which is sufficient for a lot of receivers.
Regards.Comment
Sent from my GT-I9100 using TapatalkAttached FilesComment
Hi. Thanks for that.. i see what you mean. Are you sure you definetely need the CAID, SID, PROV ID . Do you have PLTV keys inserted and if so can you send me a copy of the layout for the keys so i can check. Thanks.
RegardsComment
Hi. If only all receivers were as easy as a TM5400 for entering keys . There are very few sites that publish adult keys nowadays and most if not all require you to be a member.
RegardsComment
