Hello I'm looking to get a new reicever I have a spiderbox which is nearly to years old still reiciving the gift. can people recommend new satellite boxes with gifts please thank you
recivers with gifts
your spiderbox should carry on when the "neuvoxstream" gift runs out... you will need to patch your box with the latest patch for your version of spiderbox which will give you a gift called "ethernet" which has a very good line up of channels aswell as those available with softcam/emulator. if your insistent on getting a new gift style box then the protek 9710/9760 is similar to the spiderbox and has the excellent darkforces behind it. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
its now called ethernet when you update it, and was service plus before that , and nuevoxstream before that
no its not a linux box , its closed source like the spiderbox
probably not , but I believe a good selection can be hadComment
no, but you can source an alternative and use a c line or an n line which is the same as getting one for a blade or dreambox or vu and using it to open channels
or you get a card and share it using the newcamd feature, which is what people were expected to do (that is why its called cardshare, not payview)Comment
