Blade 7000s Channels scrambled or missing, HELP??
  • qwertyqwerty119
    • May 2012
    • 7
    Hi I have the blade media 7000s, i have firmware from Jan 2012. I have got the latest channel list from Blade online. what i am finding is that some channels appear wrong e.g. BBC 1 is actaully BBc 3. Some dont work at all e.g. Channel 4 but these can be found in the ALL Satellites group. And some like channel 5 dont work and cannot be found in all satellites even after a blind scan and an auto scan. This happens for several channels. any suggestions as to what might be wrong?
    Thanks,
  • ramjet
    • 2995
    you would have to contact blade online to ask why their channel lists are incorrect, but dont assume that theirs will be 100% accurate or up to date as transponder changes happen frequently
    I would load in a more recent list from this forum
    alternatively factory reset to clear the channel list and do your own following the manual
    but its easier to install one that somebody else has already uploaded onto the forum in other threads
    like this one http://www.digital-kaos.co.uk/forums...umbers-261478/
    • happy_highlander
      • 3535
      Or one of these http://www.digital-kaos.co.uk/forums...d.php?t=267416 the latest lists are further down the thread
      • qwertyqwerty119
        • May 2012
        • 7
        Thanks for the reply, have tried both channel lists but still getting the same problems. Some channels dont work at all such as Channel 5, sky sports news etc. Some channels appear with the wrong channel , e.g. BBC 2 appears as BBC Parliament.
        A normal sky box works fine, the channels such as 5 appear, so I don't think anything is wrong with the dish, so could it be the box? Weird as the majority of channels FTA and Pay all work.
        Any ideas?
        • ramjet
          • 2995
          sounds to me as if you may not have the universal lnb settings setup correctly, as those recent channel lists should be ok
          check its on universal lnb 9750/10600
          • qwertyqwerty119
            • May 2012
            • 7
            The dish settings i have are:
            Satellite: 28.2E
            Frequency: 10.715
            Lnb Power: On
            Lnb Type: Universal
            LNB Freq: 9,750/10,600
            DISEqC: Off
            DISEqC Motor: Off
            The settings seem ok to me?
            • ramjet
              • 2995
              Any ideas?
              seems to me your transponders are all up the creek, and you dont seem to realise sky sports news is scrambled in videoguard and therefore wont "work" (not without some help anyway)
              bbc1 is on transponder10802H 22000
              bbc2 and bbc3 are on 10773H 22000
              bbc parliament is on 10788V 22000
              c5 is on 10964H 22000
              I suggest you scan those transponders manually and then fix your channel lists yourself as nowhere in this thread have you indicated that you have done any manual scanning or channel editing yourself
              use lyngsat and kingofsat to determine correct transponders for channels
              and bear in mind c5HD and sky sports news are scrambled and so wont open without the "help" I mentioned (cs or a sly card)
              • qwertyqwerty119
                • May 2012
                • 7
                Hi I have the "help" (cs line). When I try to do a manual scan on 10964, the level/quality appear as red bars, so nothing is picked up. Most frequency's are fine, its just a few where they appear as red. Is there a way of fixing this?
                • happy_highlander
                  • 3535
                  But is it at H 22000/21999
                  • qwertyqwerty119
                    • May 2012
                    • 7
                    It is on H, 22000. Level appears as 32% and quality at 30%
                    • happy_highlander
                      • 3535
                      Have you considered a fresh install of all the latest firmware and patches then use one of the afore mentioned channel lists instead of scanning. I know for definate the 2 lists I uploaded work cause that's what I am using and the link ramjet have you is pretty reliable as well
                      • qwertyqwerty119
                        • May 2012
                        • 7
                        Ok done a factory rest via the engineer boot menu. Thing that conerns me is that the firmware was still on the box, should this have not been removed? i applied your channel list after re-installing firmware (even though system info says the firmware is already there) and still geting the same problems One thing I have noticed is that after applying channel lists i never get the option to save to normal or default db. It just saves it, its probably un-related to my current problem but worth a mention.
                        • ramjet
                          • 2995
                          no , a factory reset clears the transponders and channels on the box , not the firmware
                          the firmware will always stay with the one already installed
                          as for channel lists , you load in via usb , no saving is involved at all , loading a channel list overwrites the previous on if there, or loads into the clear space assigned for it
                          • qwertyqwerty119
                            • May 2012
                            • 7
                            Ok that clears that up, but the original problem still remains
                            • ramjet
                              • 2995
                              check you have no DECT equipment close to the box interfering with it
                              and try the box on another dish pointed at 28e, to rule out dish/lnb/coax cable issues (phone a friend)
