false advertising info
  • cactikid
    • 12017
    sky box f3 a few people have trouble wiring box to amp specs say
    Digital audio output: S/PDIF by coaxial and optical;so where is it?
  • willywonker2010
    • Mar 2010
    • 449
    conect to amp with hdmi
    audio over hdmi
    • cactikid
      • 12017
      the specs say it has those sockets,as i wire my boxes to tv with hdmi and can use either spdif or digital out to my onkyo,others are having problems using the hdmi cable to amp.
      the point was why say it has ports when there are none on the box.
        the coaxial s/pdif is there its just to the right of the RS232 and labelled 12v/50ma although there is no sign of the optical output, its probably cheaper to have one or the other than have both due to manufacturing costs
        • mdt
          • 3034
          are you sure m8 as 12v switches used to be common on sat recievers back in the day as a form of switching lnb,s before diseqc was invented by eutelsat. regards mdt
          • cactikid
            • 12017
            i asked lew that also,he said maybe used in caravan?but is that a 12v in or out which is a big difference?
              Apologies half asleep at 1:30 in the morning it is of course for 12v LNB switching
              • cactikid
                • 12017
                ok then box has no ports,wonder whats next .
                • dave-h
                  • Apr 2010
                  • 659
                  I've noticed in the blurb on some resellers sites claims of 2x scart outputs too....
