Which Box??
  • themonster
    • Jun 2012
    • 4
    Which Box??
    Ok so i've got a dreambox 500s which i bought to play around with and work out how to use it, thought for the money if i blow it up i'm not too much out of pocket.
    Now i want a reciever with HD 1080p. But i seem to be running round in circles trying to decide. I'm on a tight budget and looking for something under ?150, so unfortunately i know the all singing and dancing models are well out of my range. The options so far are:
    - Skybox F3 HD ?50
    - DM800 HD PVR (M-tuner) ?135
    - VU+ Solo HD ?119
    One feature i would like is to have the 7 day epg on 28.2e which i believe isnt available on the skybox f3, but with the price difference i could live with out it.
    Now the question is which one? can anyone help? is there another box i should be considering?
  • potrobber
    • Mar 2010
    • 493
    go for the vu solo clone its the best of the three you have picked
    no patched firmware to worry about unlike the dreambox or f3
    and its got the 7 day epg you need and a wide range of plugins
    your other options is a blade bm7000 or tm5402 these both are 1080p
    and have more or less a 7 day epg
    • micflair
      • 275
      Sky dont broadcast in 1080p, so dunno why the box being in 1080p is a big issue..
      Dont bother with the dm800 hd, the DM800se if far superior in my eyes, so much stable than the other.. with no overheating
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        they dont, but them ~~~~ing stands they have in shopping centres are showing blu ray pictures... cheeky bastards
        • themonster
          • Jun 2012
          • 4
          Well i didnt know sky dont broadcast in 1080p so you learn something new all the time.
          This is getting worse i'm getting more choices.
          So which is the best
          DM800SE or Vu+ Solo
          • nunoamorim
            • 27
            DM 800 SE, any day of the week.
            • DOUGALMCD
              • May 2011
              • 3229
              Totally unfounded it is all down to your own choice at the end of the day. Read up on both and make your choice then.
              • mdt
                • 3034
                ive put a solo clone in my bosses house and so far(3 months) its absolutley flawless... its running c**am 2.1.04 on vix 2.3 with coolmans epg with picons and for ?120 i cant recommend it highly enough for use on a fixed dish at 28.2e... regards mdt
                • Wingnut
                  • 376
                  have one myself and running a one metre dish with it and must say the box is excellent,would highly recomment it, also mine is a clone and had no probs so far
                  • cactikid
                    • 12017
                    the only problems on a vu solo may be not having a v2 sticker so people may put firmware on first rather than research done to load the new kernel or usb sticks not working.
                    • stavtoon
                      • Sep 2011
                      • 49
                      Can i chuck a GiGablue se into the ring for ?149 or twin tuner for ?169
                      gigablue quad
                      gigablue se in bedroom
                      orbital 1m motorized
                      • iGame
                        • Mar 2012
                        • 85
                        Been searching around the forum and found this:
                        • potrobber
                          • Mar 2010
                          • 493
                          http://www.digital-kaos.co.uk/forums...ot-one-260563/
                          for the money i would still have a solo clone anyday
                          • nunoamorim
                            • 27
                            DM800 - Much better supported than anything else out there.....period!
                            • contemptx
                              • 30
                              I have just about every receiver going.
                              stay away from anything closed source < sub ?100 they are really not worth it.
                              so that leaves you with the DM800 vs VU Solo.
                              DM800 clones - known issues are noisey fans and heat issues, these are easily fixed by replacing the fans and using an external cooling fan.
                              VU Solo - no noisey fan , slightly cheaper and takes original images.
                              so if your comparing those 2 boxes it has to be the VU Solo.
                              satstore.tv is a recommended shop. (they supply them setup)
                              I used to be pro DM800 but since the VU clones came along they are quality, side by side to an original you would never know! (I have the original Solo and Duo to compare!)
                              .... If you have more money in your pocket for a twin tuner go for the VU Duo Clone, you wont be dissapointed!
