Right set my 95cm up to day took nearly all day and nearly killed my self standing on the 2nd top run of fully extended ladders with a 95cm dish in my arms
This is where im stuck. I set the motor latitude to mine which is 54.5 and set the dish bracket angle to 27 and pointed it just a bit past next doors sat dish to aprox thor.
i then went in and inputted my lat etc on the dm-500 ticked the go to x and did a scan for thor. it moved the dish but didnt pick up a signal.
do i need to download a channel list and put it on a thor channel then manually move the dish till i get a pic or can i move the dish via the reciever?
do i need 2 untick go to x and reset the motor to 0 then manually add sats?
Also now the motor has moved the dish is looks a bit wonky not sure if i have done somthing stupid like put the motor the wrong way round etc.
any one got any advice and tips or can tell me where im goin wrong. im very confused
.This is where im stuck. I set the motor latitude to mine which is 54.5 and set the dish bracket angle to 27 and pointed it just a bit past next doors sat dish to aprox thor.
