Blade7000 Channel list
  • hopper28
    • 119
    Have been doing some work converting Enigma2 to CNDF is there anyone that could test the file on here for me on a Blade 7000 .
    not sure if it converted right.
  • happy_highlander
    • 3535
    It won't work too many favorites
    • hopper28
      • 119
      Hi High_Lander
      I have removed some of the FAV to cut it down to 16 can you have a look at this if you get a chance.
      • happy_highlander
        • 3535
        Hi High_Lander
        https://www.dropbox.com/s/srdfdykaibxnqlx/channell2.zip
        It's no good mate, it loads but there are only 64 channels registering on all sats and only 4 favourites, oh and by the way there is no picture or audio on any of the channels.
        • hopper28
          • 119
          Hi
          Thanks for testing
          The reason for this is because I use DM800's and changing to Blade 7000 my channel list is done with Enigma2 which I have imported into Clarks Tech Editor from their I remove some of the FAV and save it as CNDF
          Not sure where all the other sat are coming from as dreamboxedit only shows 28.2
          Do you know any other way in which I can do this without having to spend a lot of time moving things around.
          • happy_highlander
            • 3535
            Hi
            Thanks for testing
            All sats just means all available channels on list and if you are using clarke tech editor you should be saving to clarke tech plus.ndf format, I use that editor for my lists and save to that format for tm and blade use, I don't try and convert from an e2 list though, I started from scratch with a new list imported straight from kos then spent a very long time sorting it so everything was just where I wanted it, now it's just a 2 min job whenever tp's are changed which is every other day at the minute
            • hopper28
              • 119
              Thanks for that seems the only way....
              Great support
              • hopper28
                • 119
                Hi
                Any chance someone could check this file for me
                Updated to reflect Irish channels.
                • happy_highlander
                  • 3535
                  Hi
                  One word of advise mate, nobody minds helping out but to keep putting up lists for other people to try isn't good, if you are going to make channel lists you really need to be testing them yourself so that when you upload them they are ready to go.
                  Edit...I've just checked this list with clarke tech and you really need ot compare it to new list imported from kos....This will never work the video and audio pid are exactly the same for every channel and there is no pmt numbers for any channel
                  • hopper28
                    • 119
                    Hi Happy Lander
                    Just a quick note as I am waiting for the Blade to arrive if I run this channel list through NDFEDIT it shows all channels to be on 28.2 now so I'm thinking it should be working.
                    So if NDFEDIT opens up correctly and I saved it in the format you suggested all should be good. ?
                    this is the last one I'll put up until I test it myself.
                    • happy_highlander
                      • 3535
                      Hi Happy Lander
                      Don't know if you have seen my edit but this will not work ever until you sort out the video and audio pid for every channel and the pmt numbers on every channel. Before you waste anymore time on this list mate are you aware that bm7000 downloads it's own channel list with favorites sorted when pluged into ethernet
                      • hopper28
                        • 119
                        No I was not aware of this
                        again thanks
