blade7000 combo
  • pappamontanna
    • Mar 2012
    • 30
    blade7000 combo
    help with epg .only getting next 2 programs up on all channels ?
    how do i get 7 day guide? please help
  • mickydibble
    • 2166
    you might only get now and next openbox is same
    • pappamontanna
      • Mar 2012
      • 30
      blade 7000 say's 7 day epg?
      • zee24
        • 3342
        to get 7 day epg on 28e do the following :-
        first scan in transponder (manual scan) 11778V 27500 , and look for the channels like 8010 or portal video 5 that have sky trailers and info
        select that channel , then press ok and do an epg update and it will download the 7 day epg for you
        then select the guide and alter the epg as you wish using the coloured buttons
        always select either one of the channels to do the download when required, as it uses it for its epg information. After you've pressed yellow for the epg update remain on either one of these channels for a minute then you should find a full 7 day epg on most of the channels, the odd one or two channels may not have a full update this is usually the case on the International channel group, but most will.
        • zee24
          • 3342
          Ok what ive posted above is what ive been doing the past few months thanks to ramjet who advised me, but the past week these channels have gone blank they may have changed frequency so when i find it i'll post the frequency on here.
          EDIT
          just leave it on channel 8010 for a min or so to let it download the epg, this channel is showing blank at the moment with 'no audio/ video' message
          • ramjet
            • 2995
            some of you need to read the happy_highlander thread about it (as it affects the blade and the tm)
            • zee24
              • 3342
              ramjet to the rescue thanks will try it later
              • southpaw83
                • 360
                Great box, cable tuner is a godsend for me as I have a big manky tree blocking out 28.2e haha
                • zee24
                  • 3342
                  do you have a cable sub?
                  • pappamontanna
                    • Mar 2012
                    • 30
                    thank you works a treat
