channel list
  • denny111
    • Jun 2012
    channel list
    can anyone help with a spiderbox channel list
  • ramjet
    • 2995
    plenty on the forum if you check the spiderbox threads
    • Nutsandbolts
      • Oct 2011
      • 1168
      Hi Can you not do a blind scan on Spider and create your own channel list?.
      Regards.
      • Manic01
        • 5117
        Blind scan answer to everything
        • Manic01
          • 5117
          What satellite?
          Or multi sat?
          • Manic01
            • 5117
            Heres a list from Billybits at Al sat forum.
            BillyBits HD Channel List 12/05/12
            Attached is my latest Spiderbox HD channel list for the 12th May 2012.
            It has all the popular satellites from 68.5E to 61W.
            The "FREESAT UK" FAV is very family friendly with sections for "FILMS" & "KIDS", "NEWS", "MUSIC", "INTERESTS" & "SHOPPING" for those who's families use the Spiderbox
            Also there are separate satellites for feed, temporary and work in progress channels - Use these satellites for any experimenting you want to do before adding to your main satellites.
            All Satellites, Transponders and Channels are in chronological order except for 28.2E.
            28.2E has all its channels in genre blocks.
            You can easily move the blocks into the order that you prefer in the Channel Editor.
            All "FAV"s are populated with clearing channels including Ethernet, UCAS, Patched Via3 and past opening channels in case they return.
            You can easily delete those you do not want/can not receive or add any of your own channels.
            The "read me" in the archive gives information of all the extras that this channel list has and how to easily adapt the list to your needs.
            Please read it as it has a lot of information on editing the list.
            This is a full channel list - just remove the satellite/channels that you do not want.
            TV Channels: 8834 (+2 Radio) of a maximum 9800
            TPs: 1421 of a maximum 3500
            FAVs: All 8 used - FREESAT UK, SPORTS, FILMS, KIDS/MUSIC, NEWS/FACTUAL, GENERAL, ENGLISH PL, ADULT,
            The Channel List is for either USALS or DiSEqC setups - I use this list for both without any issues.
            I have included a "How To" in the archive with details of how to get the best out of your system with the combined use of USALS/DiSEqC.
            If using USALS make sure you check/input your Latitude & Longitude after loading.
            If using DiSEqC switch to "Motor (DiSEqC 1.2)" in Motor Setup - Motor Type and if using one of my lists for the first time you will need to manually locate each satellite and then store in a unique position.
            The List has Satellites from 68.5E DiSEqC "SAT Position (POS=40)" through to 61W DiSEqC "SAT Position (POS=37)"
            Any future channel lists of mine will have the same SAT Position numbers so DiSEqC users will not need to locate and store each sat position again.
            The main updates from the last list are:
            All Satellite/TP/Channel changes since my last list dated 23/3/12 have been updated.
            Lots of TPs have been modified to accommodate BISS channels with their BISS keys added.
            I've included an Excel spreadheet with BISS channel information if you want to add to the satellites that I can not receive.
            A number of channels have been renamed to be meaningful if you rescan the satellite then the names will revert back to their originals.
            The "ENGLISH PL" FAV contains any channels that show Premier League.
            Most will never open with the standard Spiderbox but you may have other means to.
            I do not have access to the "Ethernet" channels as my Spiderbox is well over 12 months old.
            The FAVs contain these channels but are unchecked by myself.
            Happy Zapping
            BillyBits
            • Nutsandbolts
              • Oct 2011
              • 1168
              Blind scans very very good...... IF you know how to do it.
              Take care.
              • ramjet
                • 2995
                Take care.
                sledgehammer to crack a nut, over populates channel lists with too many channels and transponders, doesnt sort out the wheat from the chaff and requires a lot of work to organise the favourites and delete the dross etc
                not only that, not every box can blind scan anyway
                much better to use a premade list and then alter it to suit yourself, and manually scan in anything missing like transponder changes
                there are over a dozen channel lists that have been posted for the spiderbox on this forum over the last 12 months and would take a couple of minutes to load in one of mine or billybits lists, which is less time taken and a more pleasing result than any blind scanning
                using a scalpel to do minor surgery on an ingrowing toenail is always a better option than hacking off the lower limb with a chainsaw or axe to achieve the same effect
                the point of my original reply was to get the newbie to look through the forum and not just provide answers "on a plate"
                • Nutsandbolts
                  • Oct 2011
                  • 1168
                  Hi. I think you are missing the points:
                  1) A premade list may not always contain channels that people want. By doing a blind scan it will tune in everything up to date for you so you dont need to check what TP's are missing and do manual scans. You then simply do as you are saying ie edit the channels the way you want.
                  2) To stop channel list from being overpopulated is very simple. You just delete all the TP's on a satellite before doing a blind scan. This will ensure that you dont have out of date channles/TP's etc. You just end up with TP's that are valid.
                  In my opinion it is very a simple process to do. I have done hundreds of blind scans and never had a problem.
                  Take care.
                  • ramjet
                    • 2995
                    Take care.
                    the same applies to you though, in that your tunnel vision on blind scanning hides some of MY points (and others like manic01 who have also replied)
                    1) generally speaking, a recent premade list DOES contain the popular channels that people want as that is the whole poiint of members like billybits and catseye and myself and others releasing these premade lists
                    they are usually put in order and added to the favs lists too, saving hours of work when using the remote control
                    some boxes have decent channel editors but many dont and so organising channels using the remote is laborious and time consuming and is one reason members ask for and use premade lists, especially the inexperienced members
                    it does not matter if a few channels or transponders are missing as it takes minutes to do a manual scan, save, add to favs and then organise the fav lists as required
                    a blindscan always requires you to do all the above from scratch and can take hours or days to achieve something that is easily done in minutes when using a premade list, even if it means manually scanning a few transponders for any changes or additional channels
                    2) the problem here is that you are ignoring the abilities and limits of a receiver which is that it can only handle a certain number of channels , and a certain number of transponders
                    on some boxes like linux boxes this does not matter as they can handle over ten thousand channels and over a thousand transponders, but spiderboxes and blades and eagles are limited in their capacity to hold such information and large databases and its a constant source of irritation to members who have strange results when scanning on these boxes due to the fact they have too many channels and/or too many transponders due to overscanning or blind scanning and have broken the limits
                    selective scanning or using premade lists prevents such occurrences from happening as the average joe bloggs does not think about limits placed on the number of active channels and active transponders in his list
                    he also does not care about obtaining every channel under the sun, and is usually happy to get the popular channels only and not the thousands of others you have to delete after a blindscan, as the discard rate is probably over 50%
                    3) lastly, you missed my point about precision surgery, as opposed to hacking off a foot to cure an ingrowing toenail. the end does not justify the means, and for 98% of satellite box owners a blind scan is not necessary, causes too many problems and should be avoided
                    4) blind scanning is for feed hunters, not for the average JOE who just wants bbc1, itv and sly movies and sports
                    you are so wrapped up in your blind scanning technique that you ignore all the points to the contrary, trying to justify your technique alone
                    I didnt agree with you in previous threads and would never change my mind due to the reasons laid out in this thread
                    I own an eagle, a spiderbox and a blade and know for a fact that trying to organise your channel list using your remote control is a PITA and should be avoided at all costs, especially as the editors leave a lot to be desired, if they exist at all
                    its not even helpful to do it on my dm800 either especially as it has no preview so you cannot display the channel onscreen to decide if it is the wanted channel or not (like when you have several channels of the same name like c5 or itv) , but luckily you have dreamboxedit and dreamset for organising channel lists if required (but this does not fix the display issue when editing channel lists as you cannot view them on a pc)
                    the same scenarios have always applied on my previous satellite boxes over the years too
                    the OP did not even ask about blind scanning, he asked for a list he can download (when his membership allows it)
                    my latest premade spiderbox list is here http://www.digital-kaos.co.uk/forums...72/index3.html in the setfiretorain thread which also contains his premade spiderbox list too
                    between myself, setfiretorain and the billybits lists he has 3 good choices and hopefully has every channel he would wish for already scanned in and sorted requiring very little work on his part and he would be done and dusted in 5 minutes, not 5 days
                    • gesti246
                      • Jul 2012
                      thankyou billybits for support
                      • zeevirgo
                        • Jul 2012
                        hi open box s11
                        how to configure open box s11
                        • Manic01
                          • 5117
                          @Nutsandblindscans
                          Some older receivers like TM1500ci (non super) take all day at least to do a blind scan and others even longer.
                          Newer stb's can do a satellite in 10 mins or less.
                          Why don't you stop insulting members who have far more experience in this hobby than your self?
                          • ramjet
                            • 2995
                            Hi. You must be really stupid if it takes you 5 days to do a scan. Why do you come out with this nonsense?? Read your receiver manual about blind scans you might learn something. It takes me 1 hour to scan and sort out 15 satellites. Thats because i am a genius....
                            Take care.
                            clearly you completely ignored the info in my extensive and informative post due to your blinkered approach to blindscanning, making stupid comments is not the sign of a genius, merely somebody so entrenched in their own viewpoint they miss what is happening in the real world and to try to take one small sentence like "5 days" and try to make a joke of it surely epitomises your lack of respect for anyone elses viewpoint except your own
                            the OP asked for a premade channel list, you ignored that request in order to make your own laboured point about blindscanning yet again, despite every other member pointing out you are wrong. I could have said 5 years instead of 5 days, as it was an arbritrary comment that required no meaning other than "a long time"
                            I havent seen one person agree with your blindscanning technique, yet many have agreed with my posts and other posts on this issue and there is a much greater need for channel lists for various boxes that it comes up regularly on here and I seek to help those that require such lists, especially when using bespoke receivers with limited transponder and channel capacities
                            sometimes your posts are very offensive and childish, and last nights was no exception, as it was a trolling attack on another member and nothing to do with the thread or the original request. you should be ashamed of yourself for posting such drivel
                            • Shady
                              Shite Link King
                              • Dec 2010
                              • 6404
                              i like manic he knows what hes on about, his pinkness is testament to that,
                              i like digicon, he knows his shizzle too.
                              i like nutsandbolts.
                              hes funny.... in a 'special' way
