diabloi cam help
  • bosvelt
    • 262
    diabloi cam help
    please help
    I got a diablo cam v2.3 and a cas 3, i programmed the cam with the latest underworld 162 file, put it into my TM5400 ci+ and made some changes in my technomate menu, turned off my TM and back on went to Thor 1w and Eut 16e but keep getting "no or bad signal" and "scrambled channel" messages.
    please advise
    Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorised
  • 2tone
    • 483
    you might have to change the key file in it m8 or you might not have the settings set right in the cam been a while since i used one so not sure of them
    • bosvelt
      • 262
      Do you know is there any guides on how to change key's?
      • bosvelt
        • 262
        hello 2tone
        I think i got it sorted, i loaded the latest data bin file onto the cam, so i will try this.
        • 2tone
          • 483
          hope it works if not let me know m8 and ill have a look about for the settings for it
          • bosvelt
            • 262
            Tried the cam again yesterday with the new data bin file loaded but no joy still getting "no or bad signal" and "scrambled channel" messages.
            My Tm is recognising the cam all right and i can go into change settings and stuff, i am lost now, dont know what else to do.
            • benny/9
              • 1964
              first was you able to get digialb channels before this happend ?
              i ask this because you did'nt say if you could, next is your configuration
              set correctly in the cam menu? also can you open the conax chns
              on thor 1w ? and have you loaded to-days new 1.63 file?
              if not try it and only load the the 1.63 dup file do not load the data file
              then after you have load the file set your configuration like this
              and then you should get all th channels open
              put the cam in the receiver slot and turn on
              press menu and>go to common interface and you will
              see the file name ie:underworld 1.36 highlight it
              and click>ok on the next panel go to [4] configuration
              and click>ok on the next panel set the configuration
              to the following settings useing you vol and chn buttons
              on your remote to scroll and change the menu's
              [1] language [english]
              [2] caids file [caids]
              [3] PMT - [on]
              [4] emulators [on]
              [5] N2 AU [off]
              [6] Emu priority [1:emu-2:cards]
              [7] fixed cw [on]
              [8] Smartcard mess [show never]
              [9] adminstrator menu [ do not change anything in this ]
              after you have set the cam config to the above settings
              exit the menu and turn the receiver off and on again to
              lock the settings in the cam menu,now the chns will open.
              and you dont have to format the cam everytime you load
              a new file the files overwrite one anouther
              if you do format the cam you loose all your cam settings
              and then you need to do the above again
              Please Read Carefully!
              • bosvelt
                • 262
                i wasnt able to get digitalb or thor channels only free channels, i am patching my TM and really the only sat i am viewing is digitv 0.8w.
                I will load the 163 file and try again. to see how it goes.
                • benny/9
                  • 1964
                  load the patch and the cam with 1.63 only
                  no data bin and set the cam configuration as i posted
                  but set the N2 A/U to OFF and everything will open
                  • bosvelt
                    • 262
                    when you say load the patch is that the last patch i used and do i load it the same way i previously loaded ie. with usb pen?
                    • benny/9
                      • 1964
                      if the patch you have on the technomate is'nt opening the digi-tv channels
                      and you have loaded the latest tm softcam key file and the channels
                      still dont open. then try the latest and load it with your memory stick
                      and you need to load the cam to open the conax canal+nordic chns
                      that the patch does'nt open, once both are loaded the channels will open
                      • bosvelt
                        • 262
                        Hello guys me again
                        I did what you said as above after reprogramming and changing the settings in common interface, went to Thor 1w and only 3 new channels opened BBC entertainment, Showtime and bloomberg nothing else, then went to EUT 16e and nothing at all opened.
                        However i went into my TM Menu>System Info>CAS menu and there is no info or keys for Conax, would this be the problem? and if so where/how can i get/add the Conax keys?
                        • benny/9
                          • 1964
                          Hello guys me again
                          the cam has nothing to do with the receiver patch or keys menu's
                          all the conax files and keys are on the cam chip
                          and you wont find any conax keys in the receiver menu
                          there are non the patch cant open the channels in conax
                          on thor did any digi-tv chns in nagra encryption open?
                          and if you have some conax chns open it can only be a cam setting
                          stopping the chns open just be aware there are conax channels on a different rom on thor that dont open look though the conax channels
                          to find the chns that are open there are about 150 that open, just
                          check slowly the cam needs a few moments on a channel before it opens
                          and fast chn hopping just stops the cam from opening any channels then
                          you need to turn off and on again to clear the cam memory
                          • bosvelt
                            • 262
                            I'll give it a go tomorrow again as i'm working nights, get back to you tomorrow to let you know how i get on.
                            thanks again
                            • bosvelt
                              • 262
                              guys
                              I re-scanned thor 1w and got more channels on my system (most of whats on digitv 0.8w) and they opened up but there was still some of the conax channels that would not open.
                              Also i also re-scanned eut 16e and added more channels but nothing will open what so ever any further advise please.
                              Having read 1 of the other threads it certainly looks bleak for the forseeable future, looks like i may have entered into this stuff a few years to late!!!!!
