hi lost bbc hd spiderbox 900hd how do you do a frequency change any help would be great thanks plus lost few more thanks
spiderbox
Tags: None
Hi
I have BBC HD
Frequency 10847
Symbol Rate 23000
Polarization Vertical
I have a 9900 but I assume the procedure will be similar
To add these in hit MENU
Scroll along to the picture of a Satellite hit OK
Go down to MANUAL SCAN
and enter the above information
You may have to Scroll through the modulation setting to get a signal
Make Sure Search option is set to ONE TP
Hit Start search an it should bring up the only the channels on that transponder
and you should have BBC HD in there once saved the new channels will added to the bottom of your main channel list.
Hope this helps
