satlink 6932
  • branco
    • 476
    satlink 6932
    hi
    I have a satlink 6932 sat finder
    need to add satellites list
    can some one help me
    need software and files list to send from my pc to satlink
    I bought it at second hand
  • Manic01
    • 5117
    Satlink Firmwareupdate, Satlink Satellitenliste, Satlink Software, Satlink Update
    • branco
      • 476
      thanks for reply
      this is E-SHOP
      need to make it by myself
      regards
      • mdt
        • 3034
        from what i can gather there charging for updates... id tell them to f*** off!!!! what satellite do you require? do you not have a friend with a working dish so you can do a channel scan on the needed sat then re-name it. @dick-b knows about these meters maybe he can advise you. regards mdt
        • branco
          • 476
          thanks for your support
          best regards
          • dick b
            • Jun 2009
            • 2462
            yeah the 6932 is the up market one with a spectrum analzer The 6906 I"v got I add TPs etc straight to the meter and thats good enough for what I want and I just scan channels in from an existing setup like you say mdt.There is no real need to update the 6906 as the menus allow me to alter everything I want.
            I"v sent the instructions for a 6906 which may (or may not) be of use.
            • morvina
              • Dec 2012
              that's a good idea, I will try that.
              • jotto
                • Mar 2013
                Hi. I need firmware for satlink 6932 with slovak or hungarian menu. thanks.
                • marthyh
                  • Apr 2013
                  • 5
                  Yeah let's see if this works because my brandnew WS6932 Satlink meter crashed after an upgrade of the satlist..
                  No luck with this file for flashing the Satlink WS6932..
                  • marthyh
                    • Apr 2013
                    • 5
                    Originally posted by branco
                    hi
                    To edit the list you need the program am-Channel_EditV1.1.8.exe do the edit on your PC then copy the file to the WS6932 and should work..
                    This can only be done with a usb-stick then go into the uprade menu .
                    Be very careful doing this because mine has crashed now and am waiting for support from anyone to get it going again with a bootloader or such..
