Cannot scan Nova sport on Thor
  • wooper
    • 460
    Hi all.
    Recently had motorised system but having trouble finding Nova sport on 0.8
    I get C+ sport fine on 0.8, TP 11.278V also Nova sport on 1w, TP 12.643V with the nagravision encryption. As have Diablo its not much use!!
    Have done blind scan of TP's on Thor but the transponder 12.341 does not show.
    Have deleted chanals and scaned several times.
    Its a 1 m dish near liverpool.
    I can get plenty on Thor but the one I would like.
    Any help!!!!!
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • Aug 2008
    • 5607
    reflash with latest patch..this is a common glitch...then delete that specific tp and add it in advanced search..
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • wooper
      • 460
      Thanks Sadiq,
      Have a Technomate 5400 CI+, only had it for a few months.
      Would a patch be in the technomate section? what would it be called??
      • .: JaCkPoT :.
        • Aug 2008
        • 5607
        You will see the latest one in the sticky..make sure you do NOT use the super patch..
        ___________________
        DM800s HD
        Openbox S10
        TM500
        DM500s
        Maxx 110cm Dish
        • wooper
          • 460
          Ok, looking on LYNGSAT tp 12.341 is not there anymore!!
          So no Nova with Conax.
          But, if I download the technomate patch, can I open the nagravision?? Digi TV with AU?????
          • benny/9
            • 1964
            nova sport is on this frequency
            12.643-v-27500 add it this way
            menu>advance search>ok
            on the next panel scroll down to transponder
            now press the green button
            on the next panel on the second line enter 12.643
            next line down symbol rate enter 27.500
            next line down polarisation enter v
            now you should see the signal bars
            now press the red button to save and scan
            now you have the channel
            Please Read Carefully!
            • wooper
              • 460
              Thanks Benny, you are a star.
              Was on the system last night, and as I say, LJ's football listing had Nova on 12.341 Conax encryption. Dont think this operates anymore.
              Any way, I do have Nova on that TP with Nagravision. Now it didnt open last night, but c+ did.
              I have Underworld 162 with databin dated 02/03 loaded. No patches on the system or other downloads. Cam config to how you advise in beginers guide.
              So, what do I need to open Nova with Nagra?????
              Thanks so much in advance.
              • benny/9
                • 1964
                the technomate patch will open all the digi-tv nagra channels
                just load the latest patch and let that open the chns and use
                the diablo cam for the conax chns, [digialb has gone down again to-day
                so we need a new key bin fo 16e]
                • wooper
                  • 460
                  Thanks again Benny.
                  Think I will buy a USB stick on the way home, seen them in Morrisons. Need to get some cat food!!!
                  What memory size would you advise?
                  • wooper
                    • 460
                    And last question, do I leave cam configs alone?
                    • .: JaCkPoT :.
                      • Aug 2008
                      • 5607
                      Once you have a memory stick just load the latest softcam provided that the box is patched and it should work..
                      ___________________
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      Maxx 110cm Dish
                      • wooper
                        • 460
                        Thanks sadiq, will have a bash at this tonight.
                        • benny/9
                          • 1964
                          you dont change anything in the cam config settings
                          the cam has nothing to do with the patch mate but both will
                          work together as for the memory stick 2gb will hold the patches etc
                          but if you want te recoerd on the stick go for a 4gb
                          and with the latest patch after loading MAKE SURE the A/U
                          is turned on in the options section in the receiver menu
                          then the patch will autoupdate the keys if they change
                          • wooper
                            • 460
                            Thanks Benny and Sadiq, will have a go tonight.
                            Thanks for your help with this!
