Port trigger/forward issue..
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    This probably is the wrong section but its all for a satellite purpose and i know those who read this section may have gone through similar problems before and i welcome their resolutions
    This is doing my head in.. i have a belkin router being used as a modem, i then have a netgear being used as a router.
    I have port forwarded the port i need for my DM to the DM ip.. When i use a port scanner internally ie via wifi on a phone, the port shows as open.. when i use an external one ie; canyouseeme.org it says the port is closed. The DM ip has been placed on the DMZ..
    Firewall has been turned off on the belkin router which is being used soleley as the modem, and the portforwarding has been done via the router..
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
  • ramjet
    • 2995
    for the port to be open your dm has to have opened it using cccam or oscam, so the emu has to be actively working and opening the port
    its not enough to just forward a port to the dm
    assuming your dm is using oscam or cccam and the emu is active, then check your firewall settings in the netgear
    • alom5
      • 1648
      ramjet is correct in what he says!
