motorised dish????
  • andy211081
    • 575
    motorised dish????
    been asked before but would just like a definitive answer if possible...i move in a few weeks and am looking for a motorised dish to use with a dm800se...i will use my duos on a seperate fixed dish for 28.2e and want a dish to mess about with...anyone point me to a dish they recommend including all the fixings etc...i will install myself...
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
  • mdt
    • 3034
    triax td110 and tm2600 motor or a gibertini 1m with a stab100. regards mdt
    • andy211081
      • 575
      thanks for that can you point me in the right direction? do wos sell these ones?
        WOS only stock the Triax dish but not the TD110 but they do stock the TM2600 as well as the Darkmotor.
        You wont get the Gibertini or the STAB from there as they are not official stockists, Believe it or not i know it gets mentioned on here a lot but WOS are not the only Online retailer that stock satellite equipment.
        You would also have to consider your budget a TD110 and TM2600 average price would be around ?90 for the two, on the other hand the Gibby 1m and STAB100 would be nearer the ?160 but these are quality items and far surpass what Triax and TM make and will probably last 3x longer as well.
        Last bit of advice please dont go for one of these ?99 1m dark mount etc... they are crap i have seen them and also had to rectify them most may have a decent motor but the LNB,Dish,Mount will be utter crap.
        Take mdt's advice but also figure in a black ultra LNB as well as T&K's which will allow for a small amount of user error say if they are not perfectly straight or your wall is out, Good thing about T&K's is you can adjust them a standard 'L' shaped wall mount has to be right first time.
        Good luck in your choice.
        • ramjet
          • 2995
          I bought my triax TD110 several years ago and its served me well and still looks almost new
          this year I changed to a darkmotor superior from an older tm clone (Technomate TM2100) called a Moteck SG2100 Diseqc Motor and I changed to the ultrablack twin output lnb too
          the differences are well worth it as the motor is smooth to operate , the new inverto black is better than my previous inverto silverline twin and overall its a good package
          one downside is the F connectors are hard to get at once its been installed so attach the coaxial cables if you can first before bolting it up
          I have also sparayed mine after installation with smooth black hammerite paint to try to stop the rust that the old one suffered from due to the weather, ensuring only to cover the metal plates etc, not the mechanism
          so a few options exist, but as mentioned dont get the cheap stuff, it wont last
