How do I setup cccam & cline on a spiderbox..?
Setting up cccam on spiderbox
here you go a .pdf guide
you cannot install cccam as the box is closed source and has cccam 2.14 embedded into the bespoke patch, and this cannot be altered by the user
you are mixing up closed source boxes and open source linux boxes, two totally different architecturesComment
Cheers mate. The usb install seems far handier but the link for server.cfg is not working.
And step 3. Send file to Spiderbox.
How do i do this, do I just start box up with usb stick inserted and it will automatically install or do I need to select a menu option to manually install..Comment
