motor dish already set up new box
  • kingd
    • 27
    Good morning to all sat heads
    i have a problem with a friends set up and would like some help if pos
    he has a 1.2m dish set up with motor already instaled
    he had a dm500 that stoped talking to the net and then whent bang
    i have sorted him out with a dm800 hd box
    put a image on it and loaded channel list ect
    i need to set up the box to the dish but the dish is already set to a sat how do i find what sat its at so i can set box to use usals ? please any advice very appreaciated very many thanks
    DAZA
  • ramjet
    • 2995
    I would load the catseye channel list, connect to the lnb, and go through the sats on fta channels until you find out which one it is on
    if it was on 28.2e than bbc1HD would clear
    if it was on 19e than ZDF would clear
    so as each sat has unique channels its easy enough to work out what sat you are on
    • kingd
      • 27
      ill try that thanks ill let you know how it goes
      • kingd
        • 27
        tryed that but not quite ther yet ? box says full signal on 19.2 but when i scan its on 28.2 as the sky channels all come up
        when i go to sky channels i cant sellect as they are greyed out
        help what next please many thanks daza
        • andymc1s
          • 694
          i dont have your type of box but make sure you have entered your friends correct long/latitude setting so motor can move to the desired sat.
            As andymc1s pointed out you only need to load a channel list on the box and the go to Tuner Config set to Simple - Positioner and enter your mates Lon and Lat details save and choose a channel on any satellite, The dish should move to the selected satellite and channel you chose if you have no signal then his previous install could have been setup on Diseqc 1.2.
            Which means you will have to follow the same procedure but choose Advanced Diseqc 1.2 and manually search and store the satellites.
            That is of course if your friends 1.2m dish is actually mounted on a Diseqc motor and not a 36v one.
