BISS and Irdeto 2 Keys
  • Frank1
    • Apr 2010
    • 16
    To open channels that are encrypted by BISS (PLTV on 10e), do you just put the file SoftCam.Key in var/keys or do you have to put the following lines in CCcam.cfg:-
    SOFTKEY FILE : /usr/keys/SoftCam.Key
    AUTOROLL FILE : /usr/keys/AutoRoll.Key
    STATIC CW FILE : /usr/keys/constant.cw
    Also, when using Irdeto 2 keys for Bulsat (on 39e), do you do the same with the SoftCam.Key, but use Mgcamd rather than CCcam???
    ...I have a Vu+ Duo receiver.
  • mdt
    • 3034
    basically your right m8, put the softcam in USR/KEYS and then restart mgcamd and the channels should clear,regards mdt
    • Frank1
      • Apr 2010
      • 16
      Can I use CCcam with irdeto keys?
      What is the difference between SoftCam.Key and constant.cw???
        CW's (Control Word) are often incorporated into the softcam key file so no more work is involved unlike the closed source box which has to have them manually added by remote.
        you can use any softcam you like with softcam files.
        • Frank1
          • Apr 2010
          • 16
          Do I have to use a patched Mgcamd version to open Bulsat (39e) channels with the correct keys, or will any standard version of Mgcamd open the channels?
            just use version 1.38
            • mdt
              • 3034
              if you install cccam 2.2.1,mgcamd 1.38, scam 3.60 and oscam Y mod T30 you can open all thats available with softcam/b.i.s.s. keys. theres quite a good selection of channels open with these 4 emulators... enjoy while it lasts,regards mdt
              • flyingpig
                • Aug 2009
                • 930
                I have installed CCcam 2.2.1 and Mgcamd 1.38 but still there is no SoftCam.Key file ??
                When I try to run Mgcamd my box says it will have to stop CCcam from running?
                How can I get PLTV on 10e working?
                Thanks,
                FP.
                • mdt
                  • 3034
                  Thanks,
                  FP.
                  you need to put a keypack in usr/keys... minicats,b-liner,serjoga ect ect. if using oscam y mod then you need to put a oscam.keys file in ect/tuxbox/config. stop cccam and start mgcamd 1.38 and if the softcam is up to date then pltv will open. regards mdt
                  • leez
                    • Mar 2009
                    • 321
                    can you use the biss keys softcam with enigma 2 dm 800 boxes.
                    just curious ...
                    if so i will have to use cccam 2.2.1 amd mcamd is this correct.
                    soz i aint trying to hijack thanks
                    dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
                      just curious ...
                      in a word YES all enigma2 receivers are the same and can run the same protocols
                      • flyingpig
                        • Aug 2009
                        • 930
                        Thanks champ!!! Sorted - downloaded Minicats and followed the instructions now PLTV on 10 east is working!!!!
                        Back of the net!! In off the brown!! He shoots he scores!!!
                        • Frank1
                          • Apr 2010
                          • 16
                          What's the difference between patched mgcamd and the standard mgcamd version?
                          • zamohafox
                            • Dec 2012
                            merci beaucoup
                            • jfish
                              • 799
                              from tests I did trying to open Bulsat with cccam - the irdeto2 keys would not work, so had to revert back to a patched mgcamd
