Tune Failed
  • stigmata1823
    • May 2011
    • 220
    Tune Failed
    after installing the new catseyes bouquets i have tried get Al-Jazeera sports channels but they keep saying tune failed?? anyone else had this problem?
  • digicon
    • 8261
    Could be a Corruption in the original upload of the channel list have you tried uploading again and then doing a full reboot on your receiver
    • stigmata1823
      • May 2011
      • 220
      yes buddy, i dont know whats going on it was working ok yesterday, ill try again and post back cheers
      • stigmata1823
        • May 2011
        • 220
        scanned 13oe and have got Al-Jazeera sports working but when i try to use the bouquets Al-Jazeera its all black showing na on all of them??
        • digicon
          • 8261
          Thats a sign of a corrupted list only fix is to reload and then reboot
          • stigmata1823
            • May 2011
            • 220
            I have tuner on positioner and will remove bouquets then reboot then re do bouquets then re boot again, yes
            • digicon
              • 8261
              you dont have to remove the Bouquets manually if using DBedit this will do it for you when you load the channel list again tick the 'Remove Unused Bouquets' checkbox
              • stigmata1823
                • May 2011
                • 220
                Ah still doing the same buddy I need to scan the sattelite before channels work and even then the bouquet don't work as I have to go into sattelites to select channel I want!!! What have I done wrong ??
