spiderbox 5000sd bouqets
  • bj1
    • 445
    #16
    Originally posted by ramjet
    go into your menu and make sure its on usals or diseqc as required and save
    and for usals make sure your location is correct or put it in again and save
    this is the problem in using lists from other people, you have to tailor them to fit yourself
    i did mention about usals settings
    you will have to fiddle with some sats on diseqc as the spiderbox
    is not very good for usals,
    but if you put your correct usals settings in you should be close enough then switch to diseqc to fine tune,
    i picked up sats on usals exept for 16 e intelsat 10-2 0.8 west just a little tweak on each one of them should put it right.
    • tku13523
      • Sep 2012
      same problem here
      • hackit
        • Sep 2012
        Cool it s it cool
