TM 5302 Help Need Please
  • feikuk
    • 36
    Hi, ive set my system up, i ended up with a Tm 5302 HD box, i have PLTV Set up in my channels but im having trouble entering the keys...i can get to the key menu
    The provider is set at 013387
    What do i enter in KEY is the problem
    and then does the actual 16 digit key go underneath in key data
    also there is only 1 line to enter a key, can somebody guide me through this im pulling my hair out
  • Manic01
    • 5117
    Make sure on pltv channel.
    Press 2004 on remote.
    Select Biss
    Go to any non used line and enter the 16 digits.
    exit-save.
    • feikuk
      • 36
      so do i not need to enter anything in provider & key just in key data?
      • Manic01
        • 5117
        If you are in biss and not cas then enter the 16 digits.e I do not have
        TM5302 here at the moment but it works same on other non linux technomates.
        • feikuk
          • 36
          yes i am definatly in biss, and when i try to add key i get what is in the picture
          What do i put in for provider and the other boxes
          • Manic01
            • 5117
            I am not sure, just try putting in the 16 digits and exit.
            Making sure on pltv channel to start with.
            • Manic01
              • 5117
              I am sure you dont need prov id or key just the 16 digits.
              • feikuk
                • 36
                hmm nothing happens when i press 2004, if i press mute then exit it brings me into the key menu then i scroll to biss then just enter the key but it is still scrambled, unless im putting the wrong key, the one i have starts with 2E, is that right
                • Manic01
                  • 5117
                  Yes thats correct key.
                  Are you on the pltv channel before entering kys?
                  You need to be.
                  • Manic01
                    • 5117
                    Is system patched?
                    Menu systen info -cas/biss select biss then enter 16 digit.
                    • feikuk
                      • 36
                      yes but then it gives me a list of channels in BISS, but PLTV isnt on their
                      • feikuk
                        • 36
                        i have the latest phantom patch installed
                        • Manic01
                          • 5117
                          Maybe add the name.
                          I have never entered them on TM5302 though I have owned one.
                          • feikuk
                            • 36
                            hmmm still nothing, bloody thing i need it on for tomorrow too
                            • Manic01
                              • 5117
                              Try an older patch.
                              Back up all settings/lists first.
