TM 5302 Help Need Please
  • Manic01
    • 5117
    #16
    Not sure if any use.
    You can download s/w channel list/keys from LAN by using yellow button and 0000
    • feikuk
      • 36
      #17
      tried an older patch and nothing still, 8280 doesnt respond either on the remote, entered the name also. All the other keys have a provider in though is it nothing to do with that?
      • Manic01
        • 5117
        #18
        I have never known provider id being used on biss keys before.
        • Manic01
          • 5117
          #19
          Does the line with BISS at the top toglle to change at all?
          • feikuk
            • 36
            #20
            I have edit, add delete & default listen on the add key menu thats it
            • Manic01
              • 5117
              #21
              I believe the menu is same as the TM3000 series so if you can locate a thread on those receivers for biss you may be ok.
              I have never known a provider being required for biss keys before.
              • feikuk
                • 36
                #22
                maybe iam missing something, what im doing is going to system information, press red button to edit keys, going to the biss section, press green to add enter the key details and pressing save , then returning to the channel and it still says scrambled
                • Manic01
                  • 5117
                  #23
                  Does system info state CAS/BISS
                  If so select Biss then just overwrite unused line or a line with 00000's in it.
                  • Manic01
                    • 5117
                    #24
                    Sometimes you need to go to another channel and back again to clear.
                    But make sure on pltv to start with when entering keys.
                    • feikuk
                      • 36
                      #25
                      on the picture i sent that is the only thing i can find with anything to do with biss, there are no empty lines every channel i can get has a key in it, so if i press add it brings a new thing with 00000's in every line
                      • Manic01
                        • 5117
                        #26
                        Can you give an example of what biss channels there are on there?
                        • feikuk
                          • 36
                          #27
                          megasport, nba feed, saudispor
                          ive set the dish on the right TP but pltv doesnt show in the biss key list
                          • Manic01
                            • 5117
                            #28
                            You are tuning it in ok?
                            Does megasport for example have provider id?
                            I think megasport ceased using biss long ago
                            • feikuk
                              • 36
                              #29
                              i presume so i do a scan on the TP for pltv, and afterwards it shows in the channel list with a qood quality signal, and it says scrambled channel all the time
                              • Manic01
                                • 5117
                                #30
                                You are on 10e with good signal yes?
