2nd box info please
  • mikecarey
    • Dec 2010
    • 85
    2nd box info please
    hello all, im thinkin of gettin another sat box currently on openbox s10 in living room, thinkin of one in backroom, so ive borrowed a box to test, its a nova box but i cant scan cos it doesnt search for sats its entered manually, anyone any tips on getting it to scan for the sky chans its connected to a normal sky dish
  • ramjet
    • 2995
    if its a nova box for the broadcaster nova on 13e I cannot see it being capable of accessing 28e channels
    I also would not expect a sly box to access nova sports or nova movies on 13e hotbird either
    • mikecarey
      • Dec 2010
      • 85
      can i not put in the details in the settings?
      • ramjet
        • 2995
        depends what transponder and symbol rates it accepts, and you havent said
        you would be better off with a freebie sly box as you will only get free to air channels anyway
        • mikecarey
          • Dec 2010
          • 85
          i was just wantin to test the existin wire running from rooom to room that it wud pick up the chans before sorting everything else
          • smoggie
            • 863
            why not just use the box in living to test in backroom??, save all the hassle
            • manster
              • Sep 2009
              • 229
              Will you not need 2 seperate feeds ?
              • Nutsandbolts
                • Oct 2011
                • 1168
                Hi. If you have only one dish and wish to connect two receivers you need a dual/quad LNB . You have one cable from LNB to first box and second cable from LNB to second box. To test your Nova box i would do the following:
                1) Disconnect the LNB cable at the back of Openbox receiver.
                2) Connect this LNB cable to Nova box. Make sure box is also connected to tv etc.
                3) Manually enter frequency 10774H s/r 22000 in Nova box and see if it lets you scan. It should give you BBC1, BBC2 channels etc. If it does you can try other frequencies as well.
                If all ok then you only need to connect a second cable from LNB to Nova box.
                Regards.
