I just used a magnetic spirit level for checking pole plumbness but any spirit level is fine as long as you check all around the pole (so several times in different spots)
also ensure that the dish is pointing in alignment with the motor spigot so that when its all pointing due south its all aligned, I find there are welded seams on the rear of the motor spigot and underneath the spigot in order to help with this
the motor will point at the zero mark when pointing due south so if you were at say 5 west then it would be on zero when pointing at the 5 west satellites
also set usals to your location (lat and long) and set the motor elevation to your latitude
the dish will probably be around 22 to 28 degrees of elevation, mine being on 27.5 as can be seen here
it also helps if you can use a simple box like a tm1500 or spiderbox 9000 or similar too when aligning motors and dishes
signal quality is what counts when locking onto satellites and I believe this is SNR on your box
the AGC is the signal strength and although it varies its no indicator of locking onto a satellite
