Skybox F3 / Sky dish - Newbie
  • mikeadams1985
    • Mar 2010
    • 18
    Hi,
    just after some advice if possible.
    Im pretty new to sat stuff, but as a kid remember my dad having a motorized set up that made a whirling noise above my bedroom ceiling when i was in bed some 15 years ago.
    Sky prices now take the piss with prices
    and virgin media is a joke.
    So im looking at getting a basic set up going.
    as it stands dreambox's and motorised setups out my budget for now.
    im after HD tv (1080p really not 720)
    and sky channels and 3pm football (assuming tho this will require motorized dish for foerigh signal so no biggie if i cant do that just yet.
    would the following get me started
    Skybox F3
    along with a standard sky mini dish
    and some form of css subscription.
    or am i barking up the wrong tree?
    thanks for any help
  • ramjet
    • 2995
    it wont be 1080p as no broadcasts are 1080p
    but yes its a basic box to get you going on a mini dish
    • mikeadams1985
      • Mar 2010
      • 18
      ah, ok so the box will output 1080p but no signal is 1080p yet.
      sky the robbin bastards charge for hd and only send 720p.
      robbing bastards
      is there a better box out there for a bit more cash ? im onyl wanting to start out, will invest in a dream box set up if all goes to plan
      • ramjet
        • 2995
        if you are not buying a dreambox or a vu, I would look at a blade bm7000s , or a spiderbox 7000 or 9000 , or a technomate tm5402
        the above are so much better than a skybox or an eagle
        720p is HD and is perfectly adequate for satellite broadcasts but I believe the maximum is 1080i so dont look into that aspect too deeply, even 720p is excellent quality
        the sly dish restriction will probably stop you getting any 3pm kickoffs, as you correctly pointed out you need a motorised system to take full advantage of what is out there
        • mikeadams1985
          • Mar 2010
          • 18
          thanks for the response, will look into the other boxes.
          I dont have a dish at the moment, only mentiond sly dishes as i can get em with lnb for ?20
          so would get me started.
          all upgradable in the future.
          thanks again. Off to check out the other boxes.
          will i need any form of a card in the box or can it run soley on CSS Subsciptions?
          • jovie
            • Oct 2008
            • 100
            to mikeadams1985 get a spiderbox you wont need css for
            start you can get it later gives you a good start, also
            find a bigger dish not sky dish triax or somthing like also
            good lnb if you by dreambox read up on it first regards jovie
            • dave-h
              • Apr 2010
              • 659
              robbing bastards
              All HD channels are 1080i On Sky.
                True but it also depends on where the source master is located from most if not all movies are full HD 1080i broadcast but quite a few are upscaled as well, Tv series also can vary between 720p and 1080i depending on where they source the masters from.
                Most prominently ABC in the states just show 720p masters and thats more than likely what is sourced here as well.
                So although all Sly's channels may have a resolution of 1920x1080i does not always mean that is what is being broadcast.
                • elad
                  • Sep 2012
                  • 41
                  Setanta sports1 will give you 1 premiership ko at 3 pm on a Saturday on astra 28.2 e
