2nd box and setup advice
  • kami666
    • Aug 2011
    • 6
    I have a vu duo as my main box and is a great box with no real issues.
    Now i am looking at getting a second box for the bedroom, that i can then use the signal via rf out for example to other rooms in the house.
    What would you recommend using, dont want to spend a fortune sub ?150 but would prefer something that is easy to maintain and if possible through the likes of the magic eye or similar change channels in other rooms.
    Would it be best to get a box which has rf out or to get one that doesnt and get an rf out converter?
    Any help would be appreciated, i am sure i am not the only one looking to do this. Or maybe you have done it yourself can you give me some pointers
    K
  • seamouse
    • 287
    for ?150 u could just buy 3 openboxes or so and get a feed to each room from ya sat dish mate
    MY POSTS AND ANY PM`S ARE PURELY FOR EDUCATIONAL AND LEARNING PURPOSES
    I AM FULLY RESPONSIBLE FOR MY OWN POSTS, MY POSTS ARE NOT CONDONED, MODERATED OR AUTHORISED BY ANY MEMBER OF STAFF ON THIS SITE AND I TAKE FULL RESPONSIBILITY FOR ANY CONTENT CONTAINED IN MY POSTS OR LINKED TO EXTERNALLY.
    • kami666
      • Aug 2011
      • 6
      Yeah but unfortunately its to 4 rooms, and also if its seperate boxes it means more broadband connections etc etc. the rooms already have coax to them for distribution so seems like the easiest option
      • ontherack
        • Apr 2011
        • 1080
        would wifi or home plugs not do
        • kami666
          • Aug 2011
          • 6
          Yes but that's 5 boxes total bedroom plus the 4 rooms i wanted to distribute the signal too costing ?50 each plus 6 home plugs or 5 wifi adapters plus 5 lines.
          Thought it would be better to use one box and just send the signal through rf and maybe use a magic eye or similar
          • seamouse
            • 287
            but the other rooms will only be whats on main box u cant watch other channels via rf
            • gracieboo
              • Dec 2010
              • 368
              Yeah as seamouse says you would only be able to watch one programme at anyone time through the rf. You need a quad lnb or octo lnb for more outputs to each reciever. You could have loop through signal but could only have one box on at a time, so as not to overpower the lnb.
              • seamouse
                • 287
                one cheap box and a wifi bridge or usb dongle also some boxes if a HD box, if you turn on rf feed, you cant watch HD on that box
                • kami666
                  • Aug 2011
                  • 6
                  Hi all thanks for the many replies.
                  I understand I will only be able to watch the same channel in all the rooms, this is not an issue. I have very slow broadband connection and unfortunately cant get any faster due to the distance I am from the exchange this also limits the amount of connections I could have to run without glitching so separate boxes wouldn't work due to this, so I am trying to get something working that at the least I can watch whatever channel is being watched but in the other rooms.
                  I would like to change the channel from the other rooms, only one person would be in control of changing th channel but would save going to the box everything I wanted to switch channel.
                  • cactikid
                    • 12017
                    you mentioned an rf output,what about an old vcr? if thinking of a second box i use a vu solo original and that can access recordings on the duo for looking at elsewhere,now if you got a solo and used the scart to vcr and Proception 4 Way TV Amplifier with Bypass maybe others could comment.
                    • kami666
                      • Aug 2011
                      • 6
                      Hi sounds interesting idea, need to try and source an old VCR and give it a try, not had a VCR for over 10 years didn't think they still existed :-)
                      • Manic01
                        • 5117
                        TM5402 has rf out.
                        • kami666
                          • Aug 2011
                          • 6
                          Is the tm5402 a good box? Any ideas on a system for allowing me to switch the channels from another room
