I am currently running a Dm500s using a sky minidish. But im looking to upgrade it as im setting a Dm800HD in another room. As i have a very early minidish (1999), i have been told that the LNB cant be changed.
Also, with a bigger/better dish i assume i should get a better signal and less interuption during bad weather.
The minidish is 40cm so looking to get a 60/65cm dish. As this is 50% larger, i presume it will be much better?
Also, the general opinions are that solid is beter than mesh so will be getting a solid.
I will also be adding a quad LNB to future proof it.
So the question is, what dish and lnb would you reccomend? I have a budget of around ?70 for the pair.
Is this any good? Triax TD64 64cm Solid Satellite Dish Freesat Sky Free To Air | eBay
