Technomate TM-2600 Manual
  • Curious123
    • 2591
    I want to realign my dish and motor but cannot the manual that came with the motor. This is the leaflet that comes in the box and tells you what angles you need to set for elevations etc depending on your location for your motor and dish. Any chance someone has the manual in a pdf file and could upload it?
  • dick b
    • Jun 2009
    • 2462
    is this what you want?
    • chic.
      • 1599
      hi m8 see if this helps i found it on another forum Help with TM-2600 motor setup - Techwatch Support Forums: Digital & Satellite TV, FTA, Cable, Computers, Mobile Phones, Apple and General Tech Forums
      if i helped hit the thanks btn
      • Curious123
        • 2591
        Hello & thanks for uploading the file. I have downloaded the file but could not open the file. I renamed it as pdf file but still could not open it, what type of ifle is it?
        • Manic01
          • 5117
          Its just an ordinary folder in a zip file.
          Opened ok for me.
          • Curious123
            • 2591
            Opened ok for me.
            What type of file is it and can you open it and see the content? PDF, Word , TXT?
            • Nutsandbolts
              • Oct 2011
              • 1168
              Hi. Here is a TM2600 guide for angles. Hope it helps you. To be honest i have installed numerous TM2600 motors and dont use the guide. I just line it up on any satellite i can find and then adjust the dish angles to get the arc. The TM2600 motor is pretty simple and accurate to set up.
              • Curious123
                • 2591
                A couple of months back the wind blew the dish out of alignment so I bolted it back up roughly pointed at 28.2E. I know I have got dish set at an odd angle because it is missing part of the arc. My long & lat are 1.93 & 52.53 but to get maximum reception over the arc I have to set my USALS at 4.15 & 52.53. Hopefully I can get it re-aligned so thank you for uploading the guide.
                • Nutsandbolts
                  • Oct 2011
                  • 1168
                  Hi. Please remember always to make sure that all connections are secured tight so the dish/motor does not slip. Dont forget to get the west satellites you may need to raise the motor tail up. If you were getting the arc before then you should be able to get it again.
                  Good luck.
                  • sattyboy
                    • Oct 2012
                    Is this motor reliable?
                    • Nutsandbolts
                      • Oct 2011
                      • 1168
                      Hi. I can only give you my opinion as i have installed many of these motors and in 3 years i have had not one complaint. The accuracy of the motor is breathtaking. Easy to set up . But i suggest that before you commit yourself look at other motors which may interest you.
                      Regards
                      • john9er
                        • Feb 2013
                        I think this motor is a rebranded moteck sg2500 so it should be pretty reliable and accurate. As close as you can get to an actuator
                        • Nutsandbolts
                          • Oct 2011
                          • 1168
                          Hi.. The TM2600 is not pretty reliable but very reliable. Like i said in over 3 years i never had one complaint apart from customers who mess up things by doing factory restores and losing motor alignments etc. Also motor is very easy to set up and cheap as well in my opinion.
                          Take care.
                            Hmmm! Diseqc motor as reliable and accurate as an Actuator not in the same league
                            • reggy1976
                              • Dec 2011
                              so need this manual to got givin a 2600 and need the heads up
