Multi LNB Disesqc 13E, 19.2E, 28.2E equipment
  • duglish
    • Feb 2011
    • 87
    #16
    What about the Elevation on the dish. What should I set that 2? It says 25.6 for 19.2 in my location
    • mdt
      • 3034
      #17
      Originally posted by duglish
      Doing this tonight.
      13E and 19.2E
      Should i point the dish at 19.2E or 13E?
      Dug
      point it at 13e as its slightly weaker than 19.2e,regards mdt
      • mdt
        • 3034
        #18
        start at 25 then ajust to peak the signal... dont forget to skew the lnb and ajust the focal length also to peak it aswell,regards mdt
        • duglish
          • Feb 2011
          • 87
          #19
          Looks like 28.2E is going to have to stay on the back of the house.
          And 13E and 19.2E on the front for me to get a signal anyone else ever had to do anything like this?
          • ramjet
            • 2995
            #20
            yes, my 28e is on the side but front of my house and a 30w dish on the rear of the house, and I have setup a few where dishes are in different positions so there is nothing unusual about it, as long as it works thats all that matters
            • duglish
              • Feb 2011
              • 87
              #21
              Would it be worth trying to get 0.8W, 19.2E and 13E
              or is that impossible?
              (doing it tomorrow now! it's getting dark too early!!)
              • dick b
                • Jun 2009
                • 2462
                #22
                I think youll be pushing your luck to try for 0.8W as its a 14 degree difference from 13E and I dont think thats achievable on a small dish.
                • duglish
                  • Feb 2011
                  • 87
                  #23
                  Ok so i done it
                  Port 2 on LNB splitter doesn't work
                  And when I put 3 LNBs in they all don't work
                  i am using a openbox s10 ?
                  Could it be the Disesqc thats crap and stopping the signal as signal quality drops on 19.2E to 10%
                  • dick b
                    • Jun 2009
                    • 2462
                    #24
                    do they work if you bypass the diseqc switch?is your box set to diseqc1.0 with the sats assigned to seperate ports?exactly how have you set it all up?
                    • duglish
                      • Feb 2011
                      • 87
                      #25
                      All of the above is done. I've fed 19.2E and 13E into diseqc and then 28.2 direct into house (suppose ill just have to alternate) unless there is another option? I think maybe the diseqc could be the problem? Not to sure
                      • dick b
                        • Jun 2009
                        • 2462
                        #26
                        so you can confirm that if you bypass the diseqc switch you recieve good signal/picture on both 13E & 19E.
                        when set up for diseqc 1.0 it should look something like the sketch
                          #27
                          If its the Max digital diseqc switch you posted on the first page then i never rate there stuff especially dishes they are crap.
                          As mentioned feed each individual feed into the openbox and if thats ok then its the switch
                          • duglish
                            • Feb 2011
                            • 87
                            #28
                            Could be the disesqc then. I've had to go with 13e and 19.2e off the disesqc then 28.2 direct feed into house. However 28.2 signal is a lot weaker on most channels. Is it because I have 3 lnbs on 1 dish? ( the LNB broke on my normal sky dish) I am thinking to order a new LNB for that. How would I know if I have a decent signal for 19.2E and 13E what are the weakest transponders? I should probably check them to see I everything is fine?
                            • ramjet
                              • 2995
                              #29
                              a new sly quad lnb with legacy bracket is usually about ?6 on fleabay so suggest you get it changed and use that feed into the diseqc instead of 3 lnb,s on the one dish
                              however, if the dish and lnb,s are setup correctly you can get reasonable signals across all 3 if the dish is pointing at 19e (or maybe at 13e depending on dish size)
                              but the better solution is 28e fixed dish with quad or octo lnb , and then 2 lnb,s on the second dish for 13e and 19e
                              it is possible to have trouble with certain diseqc switches so maybe try a different make, the chess ones seem to work fine, as would a decent named brand
                              you will find a list of suitable setup transponders on the forum here somewhere
                                #30
                                I can only go of my own install on a Zone2 using Original Zinwell quads i get 19.2? and 28.2? fine and also 13? east although the weaker tp's on 13 are hit and miss but it gets me the channels i want.
