looking for a new box what is important is 7 day recording........ does not have to be twin tuner also easy set up would help is there anything for ?150
Rob
if you want a 7 day epg then a linux box is advised. vu+solo clone with an external HDD should come in at about ?150 although as its E2 linux it will require a bit of reading to set up correctly,regards mdt
icecrypts same money or less, bout 130
as is the redline ts3000 or eaglebox bout 75
thes have iptv on....this is gonna be the future
no more cs but iptv will be the way.
openboxs are bout 65
sd dreambox clone about 60 but tricky to set up
youll always find help here tho mate
you can get a working hd box now for under fifty quid
not saying how good itd be but can be found, theres one thats not much bigger than an ipod for 90 sheets.
ive got the first two & a starviewcombo flashed as a spider for back up. happy viewing mucker
