As i explained previously this channel comes under Eutelsat 28A which is a pretty weak bird now its reaching the end of its life, anyone in the northwest that is experiencing the downpour may well struggle with this channel tonight
Where has it gone??
if u do a manual transponder scan on 12675 H 27497 im sure most will get it or 12523 f and 27500Last edited by smirnoff_rules; 24 November, 2012, 19:39.any information provided is for educational/experimental purposes only.Comment
Press menu
Go to installation
Go to TP list
Find 12523 27500 H
Press ok
Press ok
Then it will find its the channel $no nameComment
If you are using a linux receiver ie: dm800 you need to open your channel list in dbedit find the channel then change the service id etc to what it says in post 25
or just use smirnoff_rules channel list in post 38 as he has done it for you.
You can always put your own channel list back on afterwards as long as you back it up first.Last edited by Fergal; 24 November, 2012, 19:30.Comment
Ok will try that - using a 500s clone here.If you are using a linux receiver ie: dm800 you need to open your channel list in dbedit find the channel then change the service id etc to what it says in post 25
Edit, i can't use the channel list i don't think as its a enigma 2 - mines a 1, i'll try editing in dbedit but i'm less than hopeful.Last edited by owen7; 24 November, 2012, 19:39.Comment
spot on smirnoff cheers... i have converted your list to e1 for 500 boxes hope you dont mind so others can use it on dm500Attached FilesComment
should be? its set to 2 in toggle..all hd still there but its just so primetime works...they can do themselves anyway for dm500... in dreambox edit load smirnoffs list from his dm800... tools...toggle...2 for e1 and 4 for e2...simple asAttached FilesComment
You're a star mate, all working nowIf you are using a linux receiver ie: dm800 you need to open your channel list in dbedit find the channel then change the service id etc to what it says in post 25
