set up switch
  • marcus1975
    • Jul 2011
    • 248
    set up switch
    Hi
    I am trying to set up my diseqc switch 2x1 ?
    I have a motor set up and a fixed dish pointing at 28.2e
    Please can some one help ?
    I have had it very close to working i think
    A guide would help very much
    DM 800se hd
    Thanks in advance
    [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
  • ramjet
    • 2995
    cant tell you the specifics for a dm800 so check the dreambox forum
    but put the motor feed on A or 1 and the fixed dish on B or 2
    have committed set to 1 for all the satellites except 28e and 2 for 28e
    you may have to set uncommitted to 1 as well
    never personally tried this on a dreambox but have my spiderbox working this way except I use a 4 way switch and have 28e on C or 3 (3rd input) with the motor on A or 1 (1st input)
    the common feed goes to your receiver
    the problems with a dreambox is all the complex settings in satellite setup as you need to tell the switch which option to use for each satellite, A or B and they generally expect you to use simple diseqc or advanced motorised instead, not a combination of both at the same time
    but messing about with commit and uncommitt should achieve what you require
    • marcus1975
      • Jul 2011
      • 248
      DM 800 se HD
      this is where i am ?
      • ramjet
        • 2995
        as I said, you really need somebody who has done it on a dreambox, but you havent posted in the dreambox section
        I think a dreambox uses AA , AB , BA , BB for the committed on a 4 way looking at your pictures, so would think the motor is AA on 1 and the dish is AB on 2 , or something like that
        you need to work out that sequence of a 4 way switch in terms of AA etc and then discount the third and fourth and use the first 2 options, one for the motor and the other for the dish
          On your tuner configuration you have to setup as Advanced and set all your motorised satellites as Diseq 1.2 and at the very end you can set the 'Use USALS for this sat' if motorised feed is in 'A' set all of these to AA and when you come to 28.2 just set as Diseqc 1.0 and 'BB'
          • marcus1975
            • Jul 2011
            • 248
            still not sorted
              Originally posted by marcus1975
              still not sorted
              Its quite simple really as i have the exact same setup at the moment on my Uno i have a motorised feed going into switch A and a 28.2? feed going into B, the only difference is i have all my sats setup as Diseqc 1.2 and there positonal number.
              If your Dark Motor in your signature was setup with USALS then all you have to do is what I mentioned previously.
