Motorise zone 2 dish
  • duglish
    • Feb 2011
    • 87
    Is it possible and is it easy to do?
    Could someone give me a little guide to point me in the right direction?
  • ramjet
    • 2995
    not easy as it doesnt have elevation adjustment
    you are better off buying a triax or gilbertini or similar dishes
    • duglish
      • Feb 2011
      • 87
      Mine came with elevation adjustment. The dish that is?
      • ramjet
        • 2995
        not all these dishes have the same bracketry
        if you feel that you can attach the one you have to a motor and adjust the dish then go ahead and try it, but I think its a suck it and see approach as none of the sly dishes I have come across will marry up to the motor mounts of stab or darkmotor or technomate motors , maybe yours is different ?
        if not I suggest you buy and use the proper dish which is designed for the job, like triax or gilbertini or similar
        there is no easy answer due to the different models of dish and bracketry that sly have used over the years, and you seem to assume they are all the same with no design changes
          you will need to modify the bracket slightly on a Zone 2 as a motor stub is around 2" and the Zone 2 is a tight fit on a 2" diameter pole. It can be done its just a little fiddly thats all.
          Probably better with ramjets advice and get a dish suitable for the Job Triax, Orbital, Gibertini etc...
          • duglish
            • Feb 2011
            • 87
            Ok you are both right had an absolute mare with this!!! Lol.
            Might aswell take this dish down and give it to someone as it's like a month old. (The Multi LNB setup I done)
            Should of just went for the motorised the first time!!!
            Which dish would you recommend?
            Cheers, Dan.
              What size are you looking at
              • duglish
                • Feb 2011
                • 87
                This is only for the footy so whatever will get me most stuff.
                0.8W / 16E / 23.5E / 13E / 19.2E / 30W?
                Would a Penta 68CM get these?
                  Should be ok dont scrimp on the LNB (black ultra), Nordic beam on 0.8? west may just be borderline on that dish.
                  • ramjet
                    • 2995
                    as mentioned above, use the inverto ultra black lnb to give the best possible results
                    as for dishes , I would have thought an 80cm or 88cm triax like a TD88, or a similar gilbertini, but am sure there are other makes that will suffice
                    the zone 2 are excellent fixed dishes for 42e , 28e , 19e , 13e and 30w. I use one with an octo on 28e and a motorised triax td110 using a darkmotor and inverto ultrablack
                    if you buy quality you never regret it, so although my dish is many years old its on its 3rd motor and maybe its 4th lnb, hopefully the last for some considerable time
                    • duglish
                      • Feb 2011
                      • 87
                      Supplier has a Triax 80CM for me should I just go with this?
                      I'm thinking though in the mean time as it's for the football.
                      Liverpool V Tottenham is on 30W on Wednesday.
                      if I get home tonight and sort this out I should be able to get 30W correct?
                      • ramjet
                        • 2995
                        sounds ok to me on both counts
                        • duglish
                          • Feb 2011
                          • 87
                          What should the LNB skew be adjusted to to get 30W? I know for 28 is offset at 3?
                          • Manic01
                            • 5117
                            Use dishpointer for fixed dish skew.
                            • ramjet
                              • 2995
                              well, given that 28e is nearly 30 east and has an offset of 3, you would think that 30w needs an offset of the opposite which is minus 3 , so it will be skewed the other way by the same amount (anti clockwise)
                              and for thor at 0.8w it would be zero which is how we usually setup a motorised dish
