Technomate 5402 Phantom patch Channel problem
  • swaps
    • Dec 2011
    • 4
    Hi all,
    I have the technomate 5402 hd and no matter how many times I download from blind search it does not grab all channels available. I have tried to download a list and add it to the receiver but that has always failed as well. Im using 120 patch 7/5/12 I downloaded it around 5 months ago. Can anyone recommend how to get all channels on ? im only pointed at 28.2 east. its not motorised as yet.
    Thanks Alan
  • happy_highlander
    • Aug 2010
    • 3535
    Use this list http://www.digital-kaos.co.uk/forums...ml#post1777633 just extract the ndf file onto usb put usb stick in box press usb button on remote select data transfer then select the channel list you have just added select normal when prompted then leave it till it says complete...But if you have lots of bits of channel lists select factory reset from settings first then select delete all channels..........Remember you will only receive free to air unless you have put a little more work in
    • swaps
      • Dec 2011
      • 4
      have tried this and....
      Have tried this and it says its worked but has not. even did the delete channels and it said its done that but I then load the list and when I go back all the channels are the same in the same order as they were. about the first 10 channels are channel 4 or variation of it. Any Ideas ?
      Tried again and it worked this time. Thanks for the help.
      Thanks Alan
      • swaps
        • Dec 2011
        • 4
        Is that a full lst ???
        I downloaded the full list but without the adult channels. I have not checked this against the full list of channels but did notice that sky 3d was not on there. I know the receiver is not 3d but its made me wonder is other channels are not on it ?
        Have now checked this and found the channels I had missed !!!
        Thanks Alan
        • happy_highlander
          • Aug 2010
          • 3535
          I think you will find that there are 3d channels on this list but as you say the box is not 3d so what does it matter whether they are there or not. These lists are updated for my own personal use and uploaded as a base start for anyone else who wants them. I will accommodate what I can but to complain about a 3d channel missing from a list that is not designed for a 3d box is kinda taking the p1ss.
          • Manic01
            • 5117
            3D works fine on TM5402, it's the tv that does the work.
