i had one and it nealy drove me mad. if you have a motorised system you will find it impossible to find sats. if you are using it on one sat it is ok.
paud
Thanks for the reply Paud123. After a bit of messing about with it I was able to set it up to work with my motorised dish. I was able to update software and scam using usb memory stick and files downloaded from the net, as a result I was able to open channels on thor 1w. My dish will now turn to astra 28.2 e 19.2e 13e 1w 30w etc
Regards Andy
Reason: more info to be added
