Protek 9760 HD keeps freezing
  • Markjackson
    • Oct 2012
    • 8
    Hi please help
    I am finally getting to grips with the Protek 9760 HD I have flashed the firmware have minimal channels due to sats setup but now have an issue that approx every 20 mins box freezes and I have to reset.
    Any ideas how I can fix this?
    Mark
    Could be a Bug in the firmware or a bad flash try and re-download the patch and flash again
    • Markjackson
      • Oct 2012
      • 8
      Ill give it a go, its really bugging me resetting every 20 mins so hope your right.
      • Markjackson
        • Oct 2012
        • 8
        Well I have re flashed the drive and no good. Could it be a fault with the receiver box? Any ideas what else I could try?
        Mark
        • jovie
          • Oct 2008
          • 100
          turn the reciever off disconnect all leads leave it over night
          with luck you find its allright regards jovie
          • dick b
            • Jun 2009
            • 2462
            as all the other suggestions plus do a factory reset in the system setup menu"restore factory defaults" but this will wipe all your channels and settings so back up your channels 1st and make a note of all your settings,you will not wipe the patch.
            I"v sent a copy of the patch I use and a motorised channel list that covers the main sats.both these are ok on my box.but do do a factory reset after patch loading.
            • Markjackson
              • Oct 2012
              • 8
              Hi all really grateful for your responses Ill give it a whirl tonight and keep my fingers crossed. Ill let you know how I get on.
              regards
              Mark
