Need to See Several Sats - Use a Diseq Switch
  • aquablue
    • Mar 2009
    • 14
    Ive been using a Diseq Switch for several years now and it really is a simple way of easily accessing between two and four satellites. Simply connect more than one dish/LNB to the switch and set the reciever (which must be diseq commpatible [such as a technomate for instance[).
    Such a reciever will allow you to select a satellite from a menu with the remote. Or you can show all channels on all satellites if you prefer.
    No more wandering around in the cold/wet/dark swiveling dishes this way and that.. ; )
    hope this helps
    aquablue
    ps this method is a darn sight cheaper, simpler, easier and much more reliable than the more complex motorised operations.. unless of course the thousands of channels found on the most common two to four satelites
    are insufficient to meet your day to day viewing requrements
